2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7, pvAccess & static build
From: Michael Davidsaver via Core-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Tue, 7 Jan 2020 04:30:01 -0800
When linking with static libraries the order of _LIBS matters.  Look up "single pass linker".
On Tue, Jan 7, 2020, 1:52 AM Torsten Bögershausen via Core-talk <[email protected]> wrote:
Hej all,
I am working to set up a travis job for our motor module "EthercatMC".
The dynamic build works, including pvAccess.
The static build fails like this:
[snip]
In function `epics::pvDatabase::PVDatabase::getRecordNames[abi:cxx11]()':
pvDatabase.cpp:(.text+0x10a6): undefined reference to
`epics::pvData::PVDataCreate::getPVDataCreate()'
pvDatabase.cpp:(.text+0x10b8): undefined reference to
[snip]
My Makefile has the following:
ifdef BASE_7_0
  EthercatMC_DBD += PVAServerRegister.dbd
  EthercatMC_DBD += PVACommonRegister.dbd
  EthercatMC_DBD += softIocPVA.dbd
  EthercatMC_DBD += registerChannelProviderLocal.dbd
endif
ifdef BASE_7_0
EthercatMC_LIBS += pvAccess
EthercatMC_LIBS += pvAccessCA
EthercatMC_LIBS += pvData
EthercatMC_LIBS += pvDatabase
EthercatMC_LIBS += pvAccessIOC
EthercatMC_LIBS += qsrv
endif
First of all, we don't use static builds @ ESS, so that I can simply
remove that JOB -
and second, I tried to find out what is missing, but without success so far.
Does anybody have an idea, what is missing ?
The whole changeset is here:
<https://github.com/tboegi/m-epics-EthercatMC/compare/2d1108c874cf^...b67da723a3b4>
And the travis JOB is here:
<https://travis-ci.com/tboegi/m-epics-EthercatMC/builds/143355047?utm_medium=notification&utm_source=email>
Thanks in advance
/Torsten
Re: EPICS 7, pvAccess & static build Johnson, Andrew N. via Core-talk
EPICS 7, pvAccess & static build Torsten Bögershausen via Core-talk
Prev: EPICS 7, pvAccess & static build Torsten Bögershausen via Core-talk
Next: Re: [Bug 1858467] Re: dbExpand.pl outputs records in non-deterministic order Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: EPICS 7, pvAccess & static build Johnson, Andrew N. via Core-talk
ANJ, 07 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
