2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Bug 1858467] Re: dbExpand.pl outputs records in non-deterministic order
From: Ben Franksen via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 07 Jan 2020 13:16:11 -0000
Am 06.01.20 um 20:45 schrieb Andrew Johnson:
> The suggested solution makes the result deterministic but still changes
> the record order. Would it be preferable to keep a list of the records
> in the order in which they were parsed? That wouldn't be hard to do if
> desirable.
An option that tells dbExpand.pl to keep the records in their original
order may be useful for some applications.
However, given that the standard purpose of dbExpand.pl is to create a
"normalized" version of the input db file via the DB_OPT flag (including
re-formatting and removing comments), additionally imposing an order
seems the more useful default behavior.BTW, this is also what the
predecessor dbst did (though with a different order: first by record
type, then by name, IIRC).
There also remains the question of whether to make the other output
commands deterministic, too.
> NB: The sense of the diff above is reversed, '-' lines normally show the
> existing code and '+' lines the new.
Sorry, I mixed up the order of commits in the git diff command.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1858467
Title:
Status in EPICS Base:
  Triaged
Status in EPICS Base 7.0 series:
  Triaged
Bug description:
  This concerns only the 7.0 branch since in 3.15 there is no
  dbExpand.pl.
  The observed non-determinism makes it hard to compare (diff) generated
  db files if DB_OPT has been set in a Makefile.
  The solution is simple, at the cost of making the procedure slightly
  less efficient:
  diff --git a/modules/database/src/tools/DBD/Output.pm b/modules/database/src/tools/DBD/Output.pm
  index 869b485..55051df 100644
  --- a/modules/database/src/tools/DBD/Output.pm
  +++ b/modules/database/src/tools/DBD/Output.pm
  @@ -118,8 +118,7 @@ sub OutputBreaktables {
   sub OutputRecords {
       my ($out, $records) = @_;
  -    foreach my $name (sort(keys %$records)) {
  -        my $rec = $records->{$name};
  +    while (my ($name, $rec) = each %{$records}) {
           next if $name ne $rec->name; # Alias
           printf $out "record(%s, \"%s\") {\n", $rec->recordtype->name, $name;
           printf $out "    alias(\"%s\")\n", $_
  Note: other output routines inside this module are similarly non-
  deterministic in their output, but they are not used by dbExpand.pl.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1858467/+subscriptions
[Bug 1858467] [NEW] dbExpand.pl outputs records in non-deterministic order Ben Franksen via Core-talk
Prev: Re: EPICS 7, pvAccess & static build Michael Davidsaver via Core-talk
Next: [Bug 1740426] Re: portable printf() spec for size_t, long long, and others Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1858467] [NEW] dbExpand.pl outputs records in non-deterministic order Ben Franksen via Core-talk
Next: [Bug 1858467] Re: dbExpand.pl outputs records in non-deterministic order mdavidsaver via Core-talk
ANJ, 24 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
