Subject: |
[Bug 1740426] Re: portable printf() spec for size_t, long long, and others |
Martin Konrad via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 07 Jan 2020 14:53:05 -0000 |
Mark, you're right, MSVC supports %z for size_t (which is certainly
preferred over the Microsoft-specific %I). This is supported at least
since VS 2015 (https://docs.microsoft.com/en-us/cpp/c-runtime-library
/format-specification-syntax-printf-and-wprintf-functions?view=vs-2015
#size-prefixes-for-printf-and-wprintf-format-type-specifiers). But I'm
not aware of a sane portable way of writing
int64_t i = 42;
printf("Works on Windows only: %I64d\n", i);
other than
printf("Works on all C99-compatible platforms: %"PRId64"\n", i);
Sure the following works
printf("Works on all C99-compatible platforms: %lli\n", (long long)i);
but I always have to pull up the standard to be sure the type I'm
casting to has sufficient size on all platforms. And it also requires
C99.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1740426
Title:
Status in EPICS Base:
Triaged
Bug description:
I've been in the habit of using '%lld' and '%zu' to print 'long long'
and 'size_t' respectively. However, the windows world needs '%I64d'
and '%Iu' instead. It would be nice to have compatibility macros for
this.
stdint.h/inttypes.h has a convention for this for the standard fixed
width types. eg. PRIx32 for 'uint32_t'. This is used like:
> printf("%"PRIx32"\n", (uint32_t)42);
http://en.cppreference.com/w/c/types/integer
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1740426/+subscriptions
Re: [Bug 1858467] Re: dbExpand.pl outputs records in non-deterministic order Ben Franksen via Core-talk
Re: EPICS 7, pvAccess & static build Johnson, Andrew N. via Core-talk
<2020>
2025
2026
[Bug 1740426] Re: portable printf() spec for size_t, long long, and others rivers via Core-talk
[Bug 1740426] Re: portable printf() spec for size_t, long long, and others Martin Konrad via Core-talk
<2020>
2025
2026
