2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Error message binding socket 5076 on vxWorks
From: Michael Davidsaver via Core-talk <[email protected]>
Date: Sun, 12 Jan 2020 08:41:14 -0800
On 1/12/20 5:57 AM, Mark Rivers wrote:
>> There is already a socket bound to UDP 5076 which is not a PVA server/client (which should share w/ SO_REUSEADDR).
> Yes, but why?
> This happens on all vxWorks IOCs, and only on vxWorks IOCs.  I don't know of anything I am doing that would be creating a socket bound to that port.
Can you try running 'inetstatShow' before 'iocInit()'?
> On 2 systems the message says <IPA> rather than 164.54.160.xxx.
Do you think this a regression against an earlier version of the pvAccessCPP module on these IOCs?
Any other upgrades recently (vxWorks)?
> 13BMA.log:Wed Jan 23 15:20:23 20192019-01-23T15:20:23.891 Error binding socket 164.54.160.74:5076: S_errno_EADDRINUSE.
> 13BMC.log:Thu Mar 14 10:54:07 20192019-03-14T10:54:07.443 Error binding socket <IPA>: S_errno_EADDRINUSE.
"<IPA>" means there is (yet another) error message buffer which is too small...
> 13BMD.log:Thu Jan  2 11:55:09 20202020-01-02T17:55:09.970 Error binding socket 164.54.160.95:5076: S_errno_EADDRINUSE.
> 13IDA.log:Thu Jan 10 11:33:39 20192019-01-10T11:33:39.369 Error binding socket 164.54.160.75:5076: S_errno_EADDRINUSE.
> 13IDC.log:Thu Jan  2 11:13:46 20202020-01-02T17:13:46.898 Error binding socket 164.54.160.94:5076: S_errno_EADDRINUSE.
> 13IDD.log:Tue Mar 26 13:47:59 20192019-03-26T13:47:59.664 Error binding socket <IPA>: S_errno_EADDRINUSE.
> 13IDE.log:Sat Jan 26 14:42:21 20192019-01-26T14:42:21.834 Error binding socket 164.54.160.99:5076: S_errno_EADDRINUSE.
> This is the output of inetstatShow on 164.54.160.75.
... omitting (I think) unrelated bits
> These are the UDP sockets on port 5076 from the above list:
> UDP   0      0      164.54.160.75.5076            0.0.0.0.*
> UDP   0      0      164.54.160.255.5076           0.0.0.0.*
> UDP   0      0      224.0.0.128.5076              0.0.0.0.*
> The 224.0.0.128 addresses are multicast?  Is this used by PVA?
Yes.  PVA uses UDP ports differently than CA (imo. for no good reason).
With CA, servers use UDP 5065 for beacons, and clients use UDP 5064 for searches.
With PVA, both clients and servers use UDP 5076 for beacons and searches.
When combined with a lack of coordination within the implementations,
each process with both a PVA client and server will always bind twice to 5076.
The use of multicast is a trick to enable unicast searches/beacons
to work in this environment.
Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Prev: Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Next: Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 12 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
