2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Error message binding socket 5076 on vxWorks
From: Mark Rivers via Core-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Sun, 12 Jan 2020 13:57:05 +0000
> There is already a socket bound to UDP 5076 which is not a PVA server/client (which should share w/ SO_REUSEADDR).
Yes, but why?
This happens on all vxWorks IOCs, and only on vxWorks IOCs.  I don't know of anything I am doing that would be creating a socket bound to that port.
On 2 systems the message says <IPA> rather than 164.54.160.xxx.
13BMA.log:Wed Jan 23 15:20:23 20192019-01-23T15:20:23.891 Error binding socket 164.54.160.74:5076: S_errno_EADDRINUSE.
13BMC.log:Thu Mar 14 10:54:07 20192019-03-14T10:54:07.443 Error binding socket <IPA>: S_errno_EADDRINUSE.
13BMD.log:Thu Jan  2 11:55:09 20202020-01-02T17:55:09.970 Error binding socket 164.54.160.95:5076: S_errno_EADDRINUSE.
13IDA.log:Thu Jan 10 11:33:39 20192019-01-10T11:33:39.369 Error binding socket 164.54.160.75:5076: S_errno_EADDRINUSE.
13IDC.log:Thu Jan  2 11:13:46 20202020-01-02T17:13:46.898 Error binding socket 164.54.160.94:5076: S_errno_EADDRINUSE.
13IDD.log:Tue Mar 26 13:47:59 20192019-03-26T13:47:59.664 Error binding socket <IPA>: S_errno_EADDRINUSE.
13IDE.log:Sat Jan 26 14:42:21 20192019-01-26T14:42:21.834 Error binding socket 164.54.160.99:5076: S_errno_EADDRINUSE.
This is the output of inetstatShow on 164.54.160.75.
ioc13ida> inetstatShow
INET sockets
Prot  Recv-Q Send-Q Local Address                 Foreign Address               State
TCP   0      0      0.0.0.0.23                    0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.111                   0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.5064                  0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.5075                  0.0.0.0.*                     LISTEN
TCP   0      0      164.54.160.75.58992           164.54.160.12.5064            ESTABLISHED
TCP   0      0      164.54.160.75.54236           164.54.160.94.5064            ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.129.63701          ESTABLISHED
TCP   0      0      164.54.160.75.58308           164.54.160.99.5064            ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.116.62090          ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.111.47064          ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.82.42658           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.99.61986           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.43.54230           ESTABLISHED
TCP   0      32     164.54.160.75.5064            164.54.160.93.51418           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.82.42662           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.82.42664           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.24.57596           ESTABLISHED
TCP   0      0      164.54.160.75.50353           164.54.160.99.5064            ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.82.42696           ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.148.59787          ESTABLISHED
TCP   0      0      164.54.160.75.5064            164.54.160.74.51446           ESTABLISHED
UDP   0      0      127.0.0.1.20005               127.0.0.1.20004
UDP   0      0      0.0.0.0.123                   0.0.0.0.*
UDP   0      0      127.0.0.1.20045               127.0.0.1.20044
UDP   0      0      0.0.0.0.111                   0.0.0.0.*
UDP   0      0      0.0.0.0.58989                 0.0.0.0.*
UDP   0      0      0.0.0.0.62001                 0.0.0.0.*
UDP   0      0      0.0.0.0.60786                 0.0.0.0.*
UDP   0      0      164.54.160.75.5076            0.0.0.0.*
UDP   0      0      164.54.160.255.5076           0.0.0.0.*
UDP   0      0      224.0.0.128.5076              0.0.0.0.*
UDP   0      0      0.0.0.0.54464                 0.0.0.0.*
UDP   0      0      0.0.0.0.49428                 0.0.0.0.*
UDP   0      0      0.0.0.0.5064                  0.0.0.0.*
UDP   0      0      0.0.0.0.55281                 0.0.0.0.*
UDP   0      0      0.0.0.0.50389                 0.0.0.0.*
UDP   0      0      0.0.0.0.56937                 0.0.0.0.*
UDP   0      0      0.0.0.0.5065                  0.0.0.0.*
UDP   0      0      0.0.0.0.51877                 0.0.0.0.*
UDP   0      0      0.0.0.0.50820                 0.0.0.0.*
UDP   0      0      0.0.0.0.61969                 0.0.0.0.*
UDP   0      0      0.0.0.0.987                   0.0.0.0.*
UDP   0      0      0.0.0.0.62807                 0.0.0.0.*
UDP   0      0      0.0.0.0.985                   0.0.0.0.*
UDP   0      0      127.0.0.1.58319               127.0.0.1.50389
UDP   0      0      127.0.0.1.52021               127.0.0.1.56937
UDP   0      0      164.54.160.75.54341           0.0.0.0.*
UDP   0      0      127.0.0.1.62285               127.0.0.1.62807
UDP   0      0      0.0.0.0.56299                 0.0.0.0.*
UDP   0      0      0.0.0.0.54349                 0.0.0.0.*
INET6 sockets
These are the UDP sockets on port 5076 from the above list:
The 224.0.0.128 addresses are multicast?  Is this used by PVA?
Sent: Saturday, January 11, 2020 8:44 PM
To: Mark Rivers
Cc: [email protected]
On 1/11/20 6:14 PM, Mark Rivers via Core-talk wrote:
> I am getting an error each time I boot my vxWorks IOCs:
> iocRun: All initialization complete
> 2020-01-12T00:15:50.825 Error binding socket 164.54.160.75:5076: S_errno_EADDRINUSE.
> 164.54.60.75 is the address of this IOC.
> The error message is always the next message after "All initialization complete".
> Is this something I am doing wrong?
> Mark
Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Prev: Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Next: Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 12 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
