Hej again,
I think there is a risk for race conditions .
for me it seams as if bind() succeeded,
but then listen() fails.
From my (limited) understanding, 2 processes are allowed to bind() to
the same
port, for whatever reasons.
process 1 may use connect() on the port (specifying local port to be
something
defined.
This is not usually used, but technically possible and allowed.)
process 2 may use listen() on the same port, listening for incomming
connections.
No both processes don’t interfere by using the same local port.
From that point of view, I would suspect that bind() can be done on the
same port
from 2 different processes without problems.
The “trouble” starts, when we want to listen() from 2 differnent
processes on
the same port,
that is not a valid use-case.
In this case, our EPICS code could handle this situation more gently,
by closing the bind() port, bind() to the next one and triy to listen.
Does this make any sense ?
/Torsten
On 06/02/20 13:44, Ralph Lange via Core-talk wrote:
Hej Torsten,
On Thu, 6 Feb 2020 at 13:35, Torsten Bögershausen
<torsten.bogershausen at ess.eu <mailto:torsten.bogershausen at ess.eu>> wrote:
if ( listen ( IOC_sock, 20 ) < 0 ) {
char sockErrBuf[64];
epicsSocketConvertErrnoToString (
sockErrBuf, sizeof ( sockErrBuf ) );
errlogPrintf ( "CAS: Listen error: %s\n",
sockErrBuf );
epicsSocketDestroy (IOC_sock);
epicsThreadSuspendSelf ();
We should be able to print out errno,
to see what is going on and why listen fails.
(could be EAGAIN ??) We need to find out...
Well, we have the error string, right? "Address already in use" is not
EAGAIN.
Also, the hanging IOC reports (casr 4) to be running on the 5064 port,
which matches the missing "dynamically assigned TCP port" warning -
sorry, I should have mentioned that in my original mail.
Cheers,
~Ralph
- Weird CAS hangup on IOC Ralph Lange via Core-talk
- Re: Weird CAS hangup on IOC Torsten Bögershausen via Core-talk
- Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
Re: My Jenkins builds fail checking out. Why? Andrew Johnson via Core-talk
Re: Weird CAS hangup on IOC Michael Davidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
