On 2/6/20 12:28 PM, Michael Davidsaver via Core-talk wrote:
My attempt to fix epicsSocketEnableAddressUseForDatagramFanout() on vxWorks (which still needs confirmation)
and RTEMS had a side-effect on Linux where it seems that SO_REUSEADDR
and SO_REUSEPORT have the same effect, but are not interchangeable.
Sorry.
I cherry-picked 8dc131dc4cc04eef3df513a978576442af9405b1 from your
branch:
iocanj> osiSockTest
1..18
ok 1 - osiSockAttach
ok 2 - epicsSocketCreate INET, DGRAM, 0
ok 3 - setsockopt BROADCAST := 1
ok 4 - getsockopt BROADCAST => 1
ok 5 - setsockopt BROADCAST := 0
ok 6 - getsockopt BROADCAST => 0
ok 7 - setsockopt MULTICAST_LOOP := 1
ok 8 - getsockopt MULTICAST_LOOP => 1
ok 9 - setsockopt MULTICAST_LOOP := 0
ok 10 - getsockopt MULTICAST_LOOP => 0
ok 11 - setsockopt IP_MULTICAST_TTL := 1
ok 12 - getsockopt IP_MULTICAST_TTL => 1
ok 13 - setsockopt IP_MULTICAST_TTL := 0
not ok 14 - getsockopt IP_MULTICAST_TTL => 1
# First test if
epicsSocketEnableAddressUseForDatagramFanout() is necessary
ok 15 - bind() to port 50463
ok 16 - bind() to 50463 error -1, 48
# Now the real test
ok 17 - bind() to port 50463
not ok 18 - bind() to 50463 error -1, 48
Results
Tests: 18
Passed: 16 = 88.89%
Failed: 2 = 11.11%
iocanj> puts strerror(48)
S_errno_EADDRINUSE
value = 10 = 0xa
Test 14 always fails on VxWorks, I just haven't had time to chase
the reason.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: Weird CAS hangup on IOC Michael Davidsaver via Core-talk
- Weird CAS hangup on IOC Ralph Lange via Core-talk
[Bug 1829770] Re: event record device support broken with constant INP Gabriel Fedel via Core-talk
<2020>
2025
2026
Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
<2020>
2025
2026
