2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: My Jenkins builds fail checking out. Why?
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "anj at anl.gov" <anj at anl.gov>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 7 Feb 2020 08:25:53 +0000
Hello Andrew and Torsten,
Thanks for your replies.
This is the Jenking log from the beginning:
19:02:09 Started by an SCM change
19:02:09 Building in workspace /jenkins/workspace/EPICS-3.15
19:02:09 +AFs-WS-CLEANUP+AF0- Deleting project workspace...
19:02:09 +AFs-WS-CLEANUP+AF0- Deferred wipeout is used...
19:02:09 +AFs-WS-CLEANUP+AF0- Done
19:02:09 Cloning the remote Git repository
19:02:09 Cloning repository https://git.launchpad.net/epics-base
19:02:09  +AD4- git init /jenkins/workspace/EPICS-3.15 +ACM- timeout+AD0-10
19:02:09 Fetching upstream changes from https://git.launchpad.net/epics-base
19:02:09  +AD4- git --version +ACM- timeout+AD0-10
19:02:09  +AD4- git fetch --tags --progress https://git.launchpad.net/epics-base +-refs/heads/+ACo-:refs/remotes/origin/+ACo-
19:02:10  +AD4- git config remote.origin.url https://git.launchpad.net/epics-base +ACM- timeout+AD0-10
19:02:10  +AD4- git config --add remote.origin.fetch +-refs/heads/+ACo-:refs/remotes/origin/+ACo- +ACM- timeout+AD0-10
19:02:10 Fetching upstream changes from https://git.launchpad.net/epics-base
19:02:10  +AD4- git fetch --tags --progress https://git.launchpad.net/epics-base +-refs/heads/+ACo-:refs/remotes/origin/+ACo-
19:02:10  +AD4- git rev-parse origin/3.15+AF4Aew-commit+AH0- +ACM- timeout+AD0-10
19:02:10  +AD4- git rev-parse 3.15+AF4Aew-commit+AH0- +ACM- timeout+AD0-10
19:02:10 ERROR: Couldn't find any revision to build. Verify the repository and branch configuration for this job.
19:02:10 +AFs-WARNINGS+AF0- Skipping publisher since build result is FAILURE
19:02:10 Sending e-mails to: dirk.zimoch+AEA-psi.ch core-talk+AEA-aps.anl.gov
19:02:10 Finished: FAILURE
So it does clean up the workspace.
I did the same manually to see what happens:
+ACQ- git init .
Initialized empty Git repository in /home/zimoch/testbuild/.git/
+ACQ- git --version
git version 1.8.3.1
+ACQ- git fetch --tags --progress https://git.launchpad.net/epics-base +-refs/heads/+ACo-:refs/remotes/origin/+ACo-
remote: Counting objects: 122729, done.
remote: Compressing objects: 100+ACU- (32243/32243), done.
remote: Total 122729 (delta 92299), reused 118838 (delta 88605)
Receiving objects: 100+ACU- (122729/122729), 96.32 MiB +AHw- 33.05 MiB/s, done.
Resolving deltas: 100+ACU- (92299/92299), done.
From https://git.launchpad.net/epics-base
 +ACo- +AFs-new branch+AF0-      3.13       -+AD4- origin/3.13
 +ACo- +AFs-new branch+AF0-      3.14       -+AD4- origin/3.14
 +ACo- +AFs-new branch+AF0-      3.15       -+AD4- origin/3.15
 +ACo- +AFs-new branch+AF0-      3.16       -+AD4- origin/3.16
 +ACo- +AFs-new branch+AF0-      7.0        -+AD4- origin/7.0
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta0 -+AD4- R3.12.0-beta0
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta1 -+AD4- R3.12.0-beta1
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta10 -+AD4- R3.12.0-beta10
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta11 -+AD4- R3.12.0-beta11
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta12 -+AD4- R3.12.0-beta12
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta13 -+AD4- R3.12.0-beta13
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta2 -+AD4- R3.12.0-beta2
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta3 -+AD4- R3.12.0-beta3
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta4 -+AD4- R3.12.0-beta4
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta5 -+AD4- R3.12.0-beta5
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta6 -+AD4- R3.12.0-beta6
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta7 -+AD4- R3.12.0-beta7
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta8 -+AD4- R3.12.0-beta8
 +ACo- +AFs-new tag+AF0-         R3.12.0-beta9 -+AD4- R3.12.0-beta9
 +ACo- +AFs-new tag+AF0-         R3.12.1    -+AD4- R3.12.1
 +ACo- +AFs-new tag+AF0-         R3.12.1.1  -+AD4- R3.12.1.1
 +ACo- +AFs-new tag+AF0-         R3.12.1.2  -+AD4- R3.12.1.2
 +ACo- +AFs-new tag+AF0-         R3.12.1.3  -+AD4- R3.12.1.3
 +ACo- +AFs-new tag+AF0-         R3.12.1.4  -+AD4- R3.12.1.4
 +ACo- +AFs-new tag+AF0-         R3.12.2    -+AD4- R3.12.2
 +ACo- +AFs-new tag+AF0-         R3.12.2.1  -+AD4- R3.12.2.1
 +ACo- +AFs-new tag+AF0-         R3.12.2.2  -+AD4- R3.12.2.2
 +ACo- +AFs-new tag+AF0-         R3.13.0-alpha2 -+AD4- R3.13.0-alpha2
 +ACo- +AFs-new tag+AF0-         R3.13.0-alpha3 -+AD4- R3.13.0-alpha3
 +ACo- +AFs-new tag+AF0-         R3.13.0-alpha4 -+AD4- R3.13.0-alpha4
 +ACo- +AFs-new tag+AF0-         R3.13.0-alpha5 -+AD4- R3.13.0-alpha5
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta1 -+AD4- R3.13.0-beta1
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta10 -+AD4- R3.13.0-beta10
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta2 -+AD4- R3.13.0-beta2
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta3 -+AD4- R3.13.0-beta3
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta5 -+AD4- R3.13.0-beta5
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta8 -+AD4- R3.13.0-beta8
 +ACo- +AFs-new tag+AF0-         R3.13.0-beta9 -+AD4- R3.13.0-beta9
 +ACo- +AFs-new tag+AF0-         R3.13.1.1  -+AD4- R3.13.1.1
 +ACo- +AFs-new tag+AF0-         R3.14.0-alpha1 -+AD4- R3.14.0-alpha1
 +ACo- +AFs-new tag+AF0-         R3.14.0-alpha2 -+AD4- R3.14.0-alpha2
 +ACo- +AFs-new tag+AF0-         R3.14.0-beta1 -+AD4- R3.14.0-beta1
 +ACo- +AFs-new tag+AF0-         R3.14.0-beta2 -+AD4- R3.14.0-beta2
 +ACo- +AFs-new tag+AF0-         R3.14.1    -+AD4- R3.14.1
 +ACo- +AFs-new tag+AF0-         R3.14.10   -+AD4- R3.14.10
 +ACo- +AFs-new tag+AF0-         R3.14.10-pre1 -+AD4- R3.14.10-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.10-rc1 -+AD4- R3.14.10-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.10-rc2 -+AD4- R3.14.10-rc2
 +ACo- +AFs-new tag+AF0-         R3.14.11   -+AD4- R3.14.11
 +ACo- +AFs-new tag+AF0-         R3.14.11-pre1 -+AD4- R3.14.11-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.11-rc1 -+AD4- R3.14.11-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12   -+AD4- R3.14.12
 +ACo- +AFs-new tag+AF0-         R3.14.12-pre1 -+AD4- R3.14.12-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12-pre2 -+AD4- R3.14.12-pre2
 +ACo- +AFs-new tag+AF0-         R3.14.12-rc1 -+AD4- R3.14.12-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.1 -+AD4- R3.14.12.1
 +ACo- +AFs-new tag+AF0-         R3.14.12.1-rc1 -+AD4- R3.14.12.1-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.2 -+AD4- R3.14.12.2
 +ACo- +AFs-new tag+AF0-         R3.14.12.2-pre1 -+AD4- R3.14.12.2-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12.2-rc1 -+AD4- R3.14.12.2-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.3 -+AD4- R3.14.12.3
 +ACo- +AFs-new tag+AF0-         R3.14.12.3-pre1 -+AD4- R3.14.12.3-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12.3-rc1 -+AD4- R3.14.12.3-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.4 -+AD4- R3.14.12.4
 +ACo- +AFs-new tag+AF0-         R3.14.12.4-pre1 -+AD4- R3.14.12.4-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12.4-rc1 -+AD4- R3.14.12.4-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.5 -+AD4- R3.14.12.5
 +ACo- +AFs-new tag+AF0-         R3.14.12.5-pre1 -+AD4- R3.14.12.5-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12.5-rc1 -+AD4- R3.14.12.5-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.6 -+AD4- R3.14.12.6
 +ACo- +AFs-new tag+AF0-         R3.14.12.6-pre1 -+AD4- R3.14.12.6-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.12.6-rc1 -+AD4- R3.14.12.6-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.7 -+AD4- R3.14.12.7
 +ACo- +AFs-new tag+AF0-         R3.14.12.7-rc1 -+AD4- R3.14.12.7-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.12.8 -+AD4- R3.14.12.8
 +ACo- +AFs-new tag+AF0-         R3.14.12.8-rc1 -+AD4- R3.14.12.8-rc1
 +ACo- +AFs-new tag+AF0-         R3.14.2    -+AD4- R3.14.2
 +ACo- +AFs-new tag+AF0-         R3.14.3    -+AD4- R3.14.3
 +ACo- +AFs-new tag+AF0-         R3.14.4    -+AD4- R3.14.4
 +ACo- +AFs-new tag+AF0-         R3.14.5    -+AD4- R3.14.5
 +ACo- +AFs-new tag+AF0-         R3.14.6    -+AD4- R3.14.6
 +ACo- +AFs-new tag+AF0-         R3.14.7    -+AD4- R3.14.7
 +ACo- +AFs-new tag+AF0-         R3.14.8    -+AD4- R3.14.8
 +ACo- +AFs-new tag+AF0-         R3.14.8.1  -+AD4- R3.14.8.1
 +ACo- +AFs-new tag+AF0-         R3.14.8.2  -+AD4- R3.14.8.2
 +ACo- +AFs-new tag+AF0-         R3.14.9    -+AD4- R3.14.9
 +ACo- +AFs-new tag+AF0-         R3.14.9-pre1 -+AD4- R3.14.9-pre1
 +ACo- +AFs-new tag+AF0-         R3.14.9-pre2 -+AD4- R3.14.9-pre2
 +ACo- +AFs-new tag+AF0-         R3.14.9-rc1 -+AD4- R3.14.9-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.0.1  -+AD4- R3.15.0.1
 +ACo- +AFs-new tag+AF0-         R3.15.0.2  -+AD4- R3.15.0.2
 +ACo- +AFs-new tag+AF0-         R3.15.1    -+AD4- R3.15.1
 +ACo- +AFs-new tag+AF0-         R3.15.1-rc1 -+AD4- R3.15.1-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.2    -+AD4- R3.15.2
 +ACo- +AFs-new tag+AF0-         R3.15.2-pre1 -+AD4- R3.15.2-pre1
 +ACo- +AFs-new tag+AF0-         R3.15.2-rc1 -+AD4- R3.15.2-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.3    -+AD4- R3.15.3
 +ACo- +AFs-new tag+AF0-         R3.15.3-pre1 -+AD4- R3.15.3-pre1
 +ACo- +AFs-new tag+AF0-         R3.15.3-rc1 -+AD4- R3.15.3-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.4    -+AD4- R3.15.4
 +ACo- +AFs-new tag+AF0-         R3.15.4-pre1 -+AD4- R3.15.4-pre1
 +ACo- +AFs-new tag+AF0-         R3.15.4-rc1 -+AD4- R3.15.4-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.5    -+AD4- R3.15.5
 +ACo- +AFs-new tag+AF0-         R3.15.5-pre1 -+AD4- R3.15.5-pre1
 +ACo- +AFs-new tag+AF0-         R3.15.5-rc1 -+AD4- R3.15.5-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.6    -+AD4- R3.15.6
 +ACo- +AFs-new tag+AF0-         R3.15.6-rc1 -+AD4- R3.15.6-rc1
 +ACo- +AFs-new tag+AF0-         R3.15.7    -+AD4- R3.15.7
 +ACo- +AFs-new tag+AF0-         R3.16.0.1  -+AD4- R3.16.0.1
 +ACo- +AFs-new tag+AF0-         R3.16.1    -+AD4- R3.16.1
 +ACo- +AFs-new tag+AF0-         R3.16.1-rc1 -+AD4- R3.16.1-rc1
 +ACo- +AFs-new tag+AF0-         R3.16.2    -+AD4- R3.16.2
 +ACo- +AFs-new tag+AF0-         R3.16.2-rc1 -+AD4- R3.16.2-rc1
 +ACo- +AFs-new tag+AF0-         R7.0.1     -+AD4- R7.0.1
 +ACo- +AFs-new tag+AF0-         R7.0.1-pre1 -+AD4- R7.0.1-pre1
 +ACo- +AFs-new tag+AF0-         R7.0.1-rc1 -+AD4- R7.0.1-rc1
 +ACo- +AFs-new tag+AF0-         R7.0.1.1   -+AD4- R7.0.1.1
 +ACo- +AFs-new tag+AF0-         R7.0.2     -+AD4- R7.0.2
 +ACo- +AFs-new tag+AF0-         R7.0.2-rc1 -+AD4- R7.0.2-rc1
 +ACo- +AFs-new tag+AF0-         R7.0.2.1   -+AD4- R7.0.2.1
 +ACo- +AFs-new tag+AF0-         R7.0.2.2   -+AD4- R7.0.2.2
 +ACo- +AFs-new tag+AF0-         R7.0.3     -+AD4- R7.0.3
 +ACo- +AFs-new tag+AF0-         R7.0.3.1   -+AD4- R7.0.3.1
 +ACo- +AFs-new tag+AF0-         ca-4.13.1  -+AD4- ca-4.13.1
 +ACo- +AFs-new tag+AF0-         database-3.17.0 -+AD4- database-3.17.0
 +ACo- +AFs-new tag+AF0-         end-of-ca-master -+AD4- end-of-ca-master
 +ACo- +AFs-new tag+AF0-         end-of-core-master -+AD4- end-of-core-master
 +ACo- +AFs-new tag+AF0-         end-of-database-master -+AD4- end-of-database-master
 +ACo- +AFs-new tag+AF0-         end-of-libcom-master -+AD4- end-of-libcom-master
 +ACo- +AFs-new tag+AF0-         libcom-3.17.0 -+AD4- libcom-3.17.0
+ACQ- git config remote.origin.url https://git.launchpad.net/epics-base
+ACQ- git config --add remote.origin.fetch +-refs/heads/+ACo-:refs/remotes/origin/+ACo-
+ACQ- git rev-parse origin/3.15+AF4Aew-commit+AH0-
dbd6f7e8079bb158b9b30eaec6a60d0327752d6a
+ACQ- git rev-parse 3.15+AF4Aew-commit+AH0-
fatal: ambiguous argument '3.15+AF4Aew-commit+AH0-': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git +ADw-command+AD4- +AFsAPA-revision+AD4-...+AF0- -- +AFsAPA-file+AD4-...+AF0-'
I have no idea what Jenkins is doing here (and why). I would simply do:
+ACQ- git checkout 3.15
Branch 3.15 set up to track remote branch 3.15 from origin.
Switched to a new branch '3.15'
However, when I do the previously failing line now, it works+ACE-
Also Jenkins is doing something different for 3.14.12 and 7.0:
19:18:21  +AD4- git rev-parse origin/3.14+AF4Aew-commit+AH0- +ACM- timeout+AD0-10
19:18:21 Checking out Revision 7dd1ea4cabade8c95cda5e677951e3b08f793487 (origin/3.14)
+AFs-...+AF0-
So instead of checking out the found revision, it tries another command to get the commit for 3.15, as if getting the
commit had failed. But it does not fail when I do it manually. Very strange. Unfortunately I don't see the (error)
output of the git commands Jenkins executes.
I have started the build manually now (normally it is started by the +ACI-Poll SCM+ACI- option on change only) and, lo and
behold, it works.
Dirk
On Thu, 2020-02-06 at 10:52 -0600, Andrew Johnson wrote:
+AD4- Hi Dirk,
+AD4-
+AD4- On 2/6/20 1:56 AM, Zimoch Dirk (PSI) via Core-talk wrote:
+AD4- +AD4- For 12 days now my Jenkins build fails for 3.15 checking out the sources:
+AD4- +AD4-
+AD4- +AD4- 19:02:10 Fetching upstream changes from https://git.launchpad.net/epics-base
+AD4- +AD4- 19:02:10  +AD4- git fetch --tags --progress https://git.launchpad.net/epics-base +-refs/heads/+ACo-:refs/remotes/origin/+ACo-
+AD4- +AD4- 19:02:10  +AD4- git rev-parse origin/3.15+AF4Aew-commit+AH0- +ACM- timeout+AD0-10
+AD4- +AD4- 19:02:10  +AD4- git rev-parse 3.15+AF4Aew-commit+AH0- +ACM- timeout+AD0-10
+AD4- +AD4- 19:02:10 ERROR: Couldn't find any revision to build. Verify the repository and branch configuration for this job.
+AD4- +AD4-
+AD4- +AD4- Builds for 3.14 and 7.0 succeed. 3.16 fails as well.
+AD4- +AD4-
+AD4- +AD4- Can somebody give me a hint what has changed and what I may have to change in my Jenkins configuration?
+AD4-  Nothing has changed as far as I know, but Launchpad does seem to be getting more unreliable. Have you tried wiping out the job's workspace to have Jenkins check out the git repo again from scratch? You can do that from the job's Workspace page.
+AD4-
+AD4- +AD4- I have:
+AD4- +AD4- Repository URL https://git.launchpad.net/epics-base
+AD4- +AD4- Branch Specifier 3.15
+AD4- +AD4-
+AD4- +AD4- For the other versions I have Branch Specifier 3.14, 3.16, and 7.0.
+AD4-  We plan to never commit anything to the 3.14 or 3.16 branches again. I have disabled my jobs for those but haven't deleted them.
+AD4-
+AD4- +AEA-Torsten +IBQ- the git commands that Jenkins uses are usually generated internally by the Jenkins software, we only get to modify them by enabling and disabling features in the specific job configuration.
+AD4-
+AD4- - Andrew
+AD4-
My Jenkins builds fail checking out. Why? Zimoch Dirk (PSI) via Core-talk
Re: My Jenkins builds fail checking out. Why? Andrew Johnson via Core-talk
Prev: [Bug 1829770] Re: event record device support broken with constant INP Gabriel Fedel via Core-talk
Next: Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: My Jenkins builds fail checking out. Why? Andrew Johnson via Core-talk
Next: Weird CAS hangup on IOC Ralph Lange via Core-talk
ANJ, 07 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
