2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1862328] [NEW] Race condition on IOC start leaves rsrv unresponsive
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 07 Feb 2020 10:21:47 -0000
Public bug reported:
We have been seeing an IOC lately that occasionally seems to boot fine,
does not print the usual "cas warning: Configured TCP port was
unavailable. [...]" messages for not being the first one on the host,
but then emits a
CAS: Listen error: Address already in use
Thread CAS-TCP (0x3337a20) suspended
and becomes CA unresponsive.
This is a race condition: Using a script that is starting two IOCs in
parallel, we can see the effect happening about 1 out of 50 times.
When rsrv starts, there is a window between checking and getting
exclusive access so that further checks fail. It turns out only active
listening sockets prevent another bind() with SO_REUSEADDR set on the
sockets. From the socket(7) manpage:
SO_REUSEADDR
Indicates that the rules used in validating addresses supplied in a bind(2) call should allow reuse of local addresses. For AF_INET sockets this means that a socket may bind, except when there is an active listening socket bound to the address.
If the second IOC calls bind() before the first IOC called listen(), the
second bind() will succeed and the second IOC will fail later when it
calls listen(). Currently it decides to go deaf (suspend the receiving
thread) at that point, but it really should go back to the phase of
testing bind() instead.
See also https://epics.anl.gov/core-talk/2020/msg00110.php
** Affects: epics-base
     Importance: Medium
         Status: New
** Tags: ca codeathon rsrv
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1862328
Title:
Status in EPICS Base:
  New
Bug description:
  fine, does not print the usual "cas warning: Configured TCP port was
  but then emits a
  SO_REUSEADDR
  the second bind() will succeed and the second IOC will fail later when
  it calls listen(). Currently it decides to go deaf (suspend the
  receiving thread) at that point, but it really should go back to the
  phase of testing bind() instead.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1862328/+subscriptions
[Bug 1862328] Re: Race condition on IOC start leaves rsrv unresponsive Ralph Lange via Core-talk
[Bug 1862328] Re: Race condition on IOC start leaves rsrv unresponsive Andrew Johnson via Core-talk
Prev: Re: Weird CAS hangup on IOC Torsten Bögershausen via Core-talk
Next: Re: Weird CAS hangup on IOC Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Weird CAS hangup on IOC Michael Davidsaver via Core-talk
Next: [Bug 1862328] Re: Race condition on IOC start leaves rsrv unresponsive Ralph Lange via Core-talk
ANJ, 28 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
