On 2/12/20 3:10 AM, Michael Davidsaver wrote:
> Hi Andrew,
> It think there was some confusion. Could you test all of the commits on
> the 'reuseport' branch in my github repo.
Scratch this. Some of the confusion is mine. I had already pushed this
to the main 7.0 branch. So just update and test that.
> https://github.com/mdavidsaver/epics-base/pull/new/reuseport
> On 2/6/20 3:10 PM, Andrew Johnson via Core-talk wrote:
>> On 2/6/20 12:28 PM, Michael Davidsaver via Core-talk wrote:
>>> My attempt to fix epicsSocketEnableAddressUseForDatagramFanout() on vxWorks (which still needs confirmation)
>>> and RTEMS had a side-effect on Linux where it seems that SO_REUSEADDR
>>> and SO_REUSEPORT have the same effect, but are not interchangeable.
>> Sorry.
>> I cherry-picked 8dc131dc4cc04eef3df513a978576442af9405b1 from your branch:
>>> iocanj> osiSockTest
>>> 1..18
>>> ok 1 - osiSockAttach
>>> ok 2 - epicsSocketCreate INET, DGRAM, 0
>>> ok 3 - setsockopt BROADCAST := 1
>>> ok 4 - getsockopt BROADCAST => 1
>>> ok 5 - setsockopt BROADCAST := 0
>>> ok 6 - getsockopt BROADCAST => 0
>>> ok 7 - setsockopt MULTICAST_LOOP := 1
>>> ok 8 - getsockopt MULTICAST_LOOP => 1
>>> ok 9 - setsockopt MULTICAST_LOOP := 0
>>> ok 10 - getsockopt MULTICAST_LOOP => 0
>>> ok 11 - setsockopt IP_MULTICAST_TTL := 1
>>> ok 12 - getsockopt IP_MULTICAST_TTL => 1
>>> ok 13 - setsockopt IP_MULTICAST_TTL := 0
>>> not ok 14 - getsockopt IP_MULTICAST_TTL => 1
>>> # First test if epicsSocketEnableAddressUseForDatagramFanout() is necessary
>>> ok 15 - bind() to port 50463
>>> ok 16 - bind() to 50463 error -1, 48
>>> # Now the real test
>>> ok 17 - bind() to port 50463
>>> not ok 18 - bind() to 50463 error -1, 48
>>> Results
>>> Tests: 18
>>> Passed: 16 = 88.89%
>>> Failed: 2 = 11.11%
>>> iocanj> puts strerror(48)
>>> S_errno_EADDRINUSE
>>> value = 10 = 0xa
>> Test 14 always fails on VxWorks, I just haven't had time to chase the reason.
>> - Andrew
>> Complexity comes for free, Simplicity you have to work for.
- Weird CAS hangup on IOC Ralph Lange via Core-talk
- Re: Weird CAS hangup on IOC Michael Davidsaver via Core-talk
- Re: Weird CAS hangup on IOC Andrew Johnson via Core-talk
Re: Results from analyzing Codacy issues Johnson, Andrew N. via Core-talk
<2020>
2025
2026
[Bug 1862328] [NEW] Race condition on IOC start leaves rsrv unresponsive Ralph Lange via Core-talk
<2020>
2025
2026
