First implementation of this feature will be done in the longout record.
The OOPT field will be added with the same options as the calcout
record, plus an additional one: "Write Once Then on Change". This will
be used to ensure that the output is executed after there is a change on
the "OUT" field, even when OOPT = On Change.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1398215
Title:
Make output records only write on change
Status in EPICS Base:
Triaged
Bug description:
Add a field to the output record types to allow them to only write a
new value to the hardware when it differs from the previous value.
This saves adding another record to implement the only-on-change
behavior, and can reduce the data communication volume for slow I/O.
Can be made backwards-compatible if the default value of this field is
output always.
Gotcha's to think about: For extended device support, if a user
changes the hardware address of a record the newly addressed device
might need to reset the "previous value" somehow to ensure it gets
written to the next time the record processes, even though the value
hasn't changed. Could be tricky, discuss...
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1398215/+subscriptions
Build failed: EPICS Base base-7.0-536 AppVeyor via Core-talk
[Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 mdavidsaver via Core-talk
<2020>
2025
2026
[Bug 1398215] Re: Make output records only write on change Joao Paulo Martins via Core-talk
<2020>
2025
2026
