2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1398215] Re: Make output records only write on change
From: Joao Paulo Martins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 20 Feb 2020 08:16:26 -0000
** Changed in: epics-base
     Assignee: Andrew Johnson (anj) => Joao Paulo Martins (joaopaulosm)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1398215
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Add a field to the output record types to allow them to only write a
  new value to the hardware when it differs from the previous value.
  This saves adding another record to implement the only-on-change
  behavior, and can reduce the data communication volume for slow I/O.
  Can be made backwards-compatible if the default value of this field is
  output always.
  Gotcha's to think about: For extended device support, if a user
  changes the hardware address of a record the newly addressed device
  might need to reset the "previous value" somehow to ensure it gets
  written to the next time the record processes, even though the value
  hasn't changed. Could be tricky, discuss...
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1398215/+subscriptions
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1398215] Re: Make output records only write on change Joao Paulo Martins via Core-talk
Next: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 20 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
