2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1862918] Re: Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 14 Feb 2020 10:52:32 -0000
Fixed by https://github.com/epics-base/epics-
base/commit/66f2a509db9195112b71f4867a5e9fbaba0fb517
** Changed in: epics-base
       Status: In Progress => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1862918
Title:
Status in EPICS Base:
  Fix Committed
Bug description:
  Codacy reports an Error level issue on an uninitialized struct member
  in modules/database/src/ioc/db/dbChannel.c line 604.
  The struct member probe.serv is not initalized. It will most likely be
  implicitly initalized to 0, but explicit initalization is best
  practise.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1862918/+subscriptions
[Bug 1862918] [NEW] Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c Karl Vestin via Core-talk
Prev: Re: [Merge] ~info-martin-konrad/epics-base:fix-crash-dbloadrecords-after-iocinit into epics-base:3.15 mdavidsaver via Core-talk
Next: [Bug 1862917] Re: Possible memory leak in modules/database/src/std/link/lnkCalc.c Karl Vestin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1862918] Re: Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c Karl Vestin via Core-talk
Next: [Bug 1862920] [NEW] Possible memory leak in modules/libcom/src/log/iocLogServer.c Karl Vestin via Core-talk
ANJ, 14 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
