2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1862917] Re: Possible memory leak in modules/database/src/std/link/lnkCalc.c
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 14 Feb 2020 10:54:06 -0000
Fixed by https://github.com/epics-base/epics-
base/commit/538f5321841276704b657f206a0f97a79178e722
** Changed in: epics-base
       Status: In Progress => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1862917
Title:
Status in EPICS Base:
  Fix Committed
Bug description:
  Codacy reports an Error level issue on a possible memory leak in
  modules/database/src/std/link/lnkCalc.c line 201.
  If the malloc for postbuf successed but the malloc for inbuf then
  fails the memory for postbuf is never freed.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1862917/+subscriptions
[Bug 1862917] [NEW] Possible memory leak in modules/database/src/std/link/lnkCalc.c Karl Vestin via Core-talk
Prev: [Bug 1862918] Re: Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c Karl Vestin via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:bit_operations into epics-base:3.15 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1862917] Re: Possible memory leak in modules/database/src/std/link/lnkCalc.c Karl Vestin via Core-talk
Next: [Bug 1862918] [NEW] Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c Karl Vestin via Core-talk
ANJ, 14 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
