2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Setting up AppVeyor builds
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Konrad, Martin" <konrad at frib.msu.edu>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Thu, 20 Feb 2020 13:02:15 -0800
I had no idea that appveyor would build from a launchpad.net repo.
I've always pushed again to github.com.  This doesn't require any special config.
On 2/20/20 12:54 PM, Konrad, Martin via Core-talk wrote:
> Hi Ralph,
> I tried to set up AppVeyor to build a branch from my personal epics-base
> Git repo on Launchpad. But so far I failed miserably...
> Here is what I tried: I created a new project pointed it to
> https://git.launchpad.net/~info-martin-konrad/epics-base realizing that
> many things do not seem to get configured automatically (not sure if
> they should). So I manually started tweaking a few things:
> Default branch: fix-log-issues
> Branches to build: Only branches specified below
> fix-log-issues
> [X] Do not build tags
> Install script: Cmd
> ci/appveyor-prepare.bat
> Build script: Cmd
> ci/appveyor-make.bat
> So far no luck, it fails with "Installation for MSVC Toolchain / 64BIT
> seems to be missing" [1].
> Am I missing something?
> Thanks,
> Martin
> [1] https://ci.appveyor.com/project/MartinKonrad/epics-base/builds/30948564
RE: Setting up AppVeyor builds Freddie Akeroyd - UKRI STFC via Core-talk
Setting up AppVeyor builds Konrad, Martin via Core-talk
Prev: Re: [Merge] ~info-martin-konrad/epics-base:fix-log-issues into epics-base:3.15 Martin Konrad via Core-talk
Next: RE: Setting up AppVeyor builds Freddie Akeroyd - UKRI STFC via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Setting up AppVeyor builds Konrad, Martin via Core-talk
ANJ, 20 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
