2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+379750 at code.launchpad.net
Date: Mon, 24 Feb 2020 15:23:23 -0000
Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/379750
This change allows to use the event freelists in dbChannel before Channel Access has started (i.e. during PINI).
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15.
diff --git a/src/ioc/db/dbChannel.c b/src/ioc/db/dbChannel.c
index 399d13d..f355af9 100644
--- a/src/ioc/db/dbChannel.c
+++ b/src/ioc/db/dbChannel.c
@@ -67,6 +67,7 @@ void dbChannelInit (void)
     freeListInitPvt(&dbChannelFreeList,  sizeof(dbChannel), 128);
     freeListInitPvt(&chFilterFreeList,  sizeof(chFilter), 64);
     freeListInitPvt(&dbchStringFreeList, sizeof(epicsOldString), 128);
+    db_init_event_freelists();
 static void chf_value(parseContext *parser, parse_result *presult)
diff --git a/src/ioc/db/dbEvent.c b/src/ioc/db/dbEvent.c
index d1f9548..f89c685 100644
--- a/src/ioc/db/dbEvent.c
+++ b/src/ioc/db/dbEvent.c
@@ -153,7 +153,7 @@ int dbel ( const char *pname, unsigned level )
     if ( ! pname ) return DB_EVENT_OK;
     status = dbNameToAddr ( pname, &addr );
     if ( status != 0 ) {
-	    errMessage ( status, " dbNameToAddr failed" );
+        errMessage ( status, " dbNameToAddr failed" );
         return DB_EVENT_ERROR;
@@ -162,7 +162,7 @@ int dbel ( const char *pname, unsigned level )
     pevent = (struct evSubscrip *) ellFirst ( &addr.precord->mlis );
     if ( ! pevent ) {
-	    printf ( "\"%s\": No PV event subscriptions ( monitors ).\n", pname );
+        printf ( "\"%s\": No PV event subscriptions ( monitors ).\n", pname );
         UNLOCKREC (addr.precord);
         return DB_EVENT_OK;
@@ -174,14 +174,14 @@ int dbel ( const char *pname, unsigned level )
         pdbFldDes = dbChannelFldDes(pevent->chan);
         if ( level > 0 ) {
-	        printf ( "%4.4s", pdbFldDes->name );
+            printf ( "%4.4s", pdbFldDes->name );
-	        printf ( " { " );
+            printf ( " { " );
                 if ( pevent->select & DBE_VALUE ) printf( "VALUE " );
                 if ( pevent->select & DBE_LOG ) printf( "LOG " );
                 if ( pevent->select & DBE_ALARM ) printf( "ALARM " );
                 if ( pevent->select & DBE_PROPERTY ) printf( "PROPERTY " );
-	        printf ( "}" );
+            printf ( "}" );
             if ( pevent->npend ) {
                 printf ( " undelivered=%ld", pevent->npend );
@@ -236,7 +236,7 @@ int dbel ( const char *pname, unsigned level )
                     ( void * ) pevent->ev_que->evUser );
-	        printf( "\n" );
+            printf( "\n" );
             pevent = (struct evSubscrip *) ellNext ( &pevent->node );
@@ -247,23 +247,17 @@ int dbel ( const char *pname, unsigned level )
     return DB_EVENT_OK;
- * DB_INIT_EVENTS()
+ * DB_INIT_EVENT_FREELISTS()
- * Initialize the event facility for this task. Must be called at least once
- * by each task which uses the db event facility
+ * Initialize the free lists used by the event facility.
+ * Safe to be called multiple times.
- * returns: ptr to event user block or NULL if memory can't be allocated
-dbEventCtx db_init_events (void)
+void db_init_event_freelists (void)
-    struct event_user * evUser;
-    if (!stopSync) {
-        stopSync = epicsMutexMustCreate();
     if (!dbevEventUserFreeList) {
         freeListInitPvt(&dbevEventUserFreeList,
             sizeof(struct event_user),8);
@@ -280,6 +274,26 @@ dbEventCtx db_init_events (void)
         freeListInitPvt(&dbevFieldLogFreeList,
             sizeof(struct db_field_log),2048);
+ * DB_INIT_EVENTS()
+ * Initialize the event facility for this task. Must be called at least once
+ * by each task which uses the db event facility
+ * returns: ptr to event user block or NULL if memory can't be allocated
+dbEventCtx db_init_events (void)
+    struct event_user * evUser;
+    if (!stopSync) {
+        stopSync = epicsMutexMustCreate();
     evUser = (struct event_user *)
         freeListCalloc(dbevEventUserFreeList);
@@ -381,7 +395,7 @@ void db_close_events (dbEventCtx ctx)
 static struct event_que * create_ev_que ( struct event_user * const evUser )
-    struct event_que * const ev_que = (struct event_que *)
+    struct event_que * const ev_que = (struct event_que *)
         freeListCalloc ( dbevEventQueueFreeList );
     if ( ! ev_que ) {
         return NULL;
@@ -425,7 +439,7 @@ dbEventSubscription db_add_event (
     while ( TRUE ) {
         int success = 0;
         LOCKEVQUE ( ev_que );
-        success = ( ev_que->quota + ev_que->nCanceled <
+        success = ( ev_que->quota + ev_que->nCanceled <
                                 EVENTQUESIZE - EVENTENTRIES );
         if ( success ) {
             ev_que->quota += EVENTENTRIES;
@@ -1093,7 +1107,7 @@ int db_start_events (
          taskname = EVENT_PEND_NAME;
      evUser->taskid = epicsThreadCreate (
-         taskname, osiPriority,
+         taskname, osiPriority,
          epicsThreadGetStackSize(epicsThreadStackMedium),
          event_task, (void *)evUser);
      if (!evUser->taskid) {
@@ -1108,7 +1122,7 @@ int db_start_events (
  * db_event_change_priority()
-void db_event_change_priority ( dbEventCtx ctx,
+void db_event_change_priority ( dbEventCtx ctx,
                                         unsigned epicsPriority )
     struct event_user * const evUser = ( struct event_user * ) ctx;
diff --git a/src/ioc/db/dbEvent.h b/src/ioc/db/dbEvent.h
index 2e496a7..7fc6198 100644
--- a/src/ioc/db/dbEvent.h
+++ b/src/ioc/db/dbEvent.h
@@ -50,6 +50,7 @@ epicsShareFunc int db_post_events (
 typedef void * dbEventCtx;
 typedef void EXTRALABORFUNC (void *extralabor_arg);
+void db_init_event_freelists (void);
 epicsShareFunc dbEventCtx db_init_events (void);
 epicsShareFunc int db_start_events (
     dbEventCtx ctx, const char *taskname, void (*init_func)(void *),
@@ -64,7 +65,7 @@ epicsShareFunc int db_post_extra_labor (dbEventCtx ctx);
 epicsShareFunc void db_event_change_priority ( dbEventCtx ctx, unsigned epicsPriority );
 typedef void EVENTFUNC (void *user_arg, struct dbChannel *chan,
-	int eventsRemaining, struct db_field_log *pfl);
+    int eventsRemaining, struct db_field_log *pfl);
 typedef void * dbEventSubscription;
 epicsShareFunc dbEventSubscription db_add_event (
Re: [Merge] ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Codacy update Karl Vestin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: qt-creator >=4.8 PSA Michael Davidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15 Dirk Zimoch via Core-talk
ANJ, 27 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
