2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: qt-creator >=4.8 PSA
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Sun, 23 Feb 2020 22:57:31 -0800
On 7/17/19 7:02 AM, Ralph Lange via Core-talk wrote:
> On Mon, 15 Jul 2019 at 19:57, Michael Davidsaver <mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>> wrote:
>     On 7/15/19 12:55 AM, Ralph Lange via Core-talk wrote:
>     > However, when set to use the VisualStudio compiler, all my throw keywords are marked with "error: cannot use 'throw' with exceptions disabled" - but I can't seem to find how to enable exceptions.
>     > Any ideas anyone?
>     Maybe ClangCodeModel.CustomCommandLineKey in the .creator file?
>     eg.
>     >    <valuelist type="QVariantList" key="ClangCodeModel.CustomCommandLineKey">
>     >     <value type="QString">-fexception</value>
>     >    </valuelist>
> Nope - does not change anything.
I happened to notice
> Forwarding Flags to Clang Code Model
> The .cxxflags and .cflags files contain command line flags for the Clang code model on a single line.
> For example, specify the -std=c++11 to set the language version for parsing as C++11.
https://doc.qt.io/qtcreator/creator-project-generic.html#forwarding-flags-to-clang-code-model
Not sure which version of qt-creator introduces this.  atm. the manual is for 4.11.1
Also, .includes can contain relative paths, which is what I was actually looking for.
Attachment: signature.asc
Description: OpenPGP digital signature
Prev: Build failed: epics-base base-fix-log-issues-9 AppVeyor via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Merge] ~dirk.zimoch/epics-base:InitEventFreelistsEarly into epics-base:3.15 Dirk Zimoch via Core-talk
ANJ, 24 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
