> Is it reasonable to assume that at most one API.h file will need to be generated per build directory?
Is it reasonable to assume that only one shared library will be built per build directory?
I can't recall wanting to do this, so I've no particular objection to this limitation.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/375942
Your team EPICS Core Developers is requested to review the proposed merge of ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0.
Static code analysis using Codacy - Submodules now enabled Karl Vestin via Core-talk
Build failed: EPICS Base base-7.0-552 AppVeyor via Core-talk
<2020>
2025
2026
Re: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 Ralph Lange via Core-talk
<2020>
2025
2026
