2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Static code analysis using Codacy - Submodules now enabled
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 28 Feb 2020 12:35:28 +0000
Dear all,
After some back-and-forth with the Codacy support team I have now enabled static code analysis for both epics-base and the associated submodules. The pattern configuration and exclusion of files is based on configuration from the codeathon. Currently enabled checkers:
cppcheck (200 active patterns. This checker finds by far the most issues)
flawfinder (13 active patterns)
shellcheck (22 active patterns)
Please note that as long as we keep using the web UI to maintain the configuration it is not possible to share configuration between the repositories. If we were to move to using configuration files we could use one set of files however. I have cloned the setup for the repositories, so they are identical now.
The current status of issues is:
Module
Information
Warning
Error
pvDatabaseCPP
6
8
0
pvAccessCPP
51
48
2
epics-base
128
18
7
pva2pva
11
3
0
pvDataCPP
10
0
2
pvClientCPP
2
0
0
normativeTypesCPP*
0
0
0
* I don’t think this is correct. Have raised the issue with Codacy support.
How to continue: I think the best way to proceed with static code analysis is to use it primarily as an additional tool for reviewing pull requests. It is a good way to avoid new releases introducing memory leaks or similar. Regarding the existing issues I think a reasonable ambition would be to remove the “Error” level issues and at some point at least have a look at the “Warning” level issues.
I hope this contribution has been somewhat useful. I am happy to answer further questions and/or analyze specific issues, but due to other commitments my available time is quite limited.
Best regards
Karl Vestin
Prev: [Bug 1862328] Re: Race condition on IOC start leaves rsrv unresponsive Ralph Lange via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:libcom-api into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Codacy update Karl Vestin via Core-talk
Next: Build failed: EPICS Base base-7.0-552 AppVeyor via Core-talk
ANJ, 29 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
