2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: IOC build fails after removing an iocBoot dir from Git
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 20 Mar 2020 09:21:54 +0100
On Thu, 19 Mar 2020 at 16:48, Konrad, Martin via Core-talk <core-talk at aps.anl.gov> wrote:
> I think you're confusing 'clean' with 'distclean'.
Yes, indeed, I did. Thanks for pointing that out. "make clean" should
actually be safe. I'll consider running that.
Works fine.
I am experimenting with that to reduce the size of the cached built dependencies in travis-ci builds.
Cheers,
~Ralph
IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
Re: IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
Prev: Re: write to a single element of an array field Ralph Lange via Core-talk
Next: C++ question Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
ANJ, 20 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
