Hi Michael,
> recGblRecordError() isn't often used. The unique part is the trailing "ReadOut".
ReadOut is the second enum choice in this record, which is a GenICam feature of that camera.
record(mbbo, "$(P)$(R)GC_TriggerOverlap") {
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_TriggerOverlap")
field(DOL, "0")
field(ZRST, "Off")
field(ZRVL, "0")
field(ONST, "ReadOut")
field(ONVL, "1")
field(DISA, "0")
My client is writing the string "ReadOut" to that PV. It works fine when the frame rate is less than 100 frames/s.
Something is going wrong for this record at higher frame rates. But acquisition is supposed to have stopped when the client writes to that PV, so the frame rate should not matter. Adding 0.1 delay in the client before writing that value does not seem to help.
I'll try to figure out where recGblRecordError() is being called.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Sunday, March 22, 2020 10:59 AM
To: Mark Rivers
Cc: EPICS core-talk
Subject: Re: Error (511,511)
On 3/22/20 8:53 AM, Mark Rivers wrote:
> Hi Michael,
> Before I got your message I got as far as figuring out that the message was from this line in errSymLib.c::errRawCopy.
> epicsSnprintf(pBuf, bufLength, "Error (%u,%u)", modnum, errnum);
> And this line in errMdef.h defines 511 to be the module Database access:
> #define M_dbAccess (511 << 16) /* Database Access Routines */
> How did you determine that it is recGblRecordError, and how do I track it down?
The string "PV: " doesn't appear in Base nearly as often as you might think.
> It is not an error I ever recall seeing before.
That's not in Base.
> Thanks,
> Mark
> ________________________________
> From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
> Sent: Sunday, March 22, 2020 10:44 AM
> To: core-talk at aps.anl.gov
> On 3/22/20 8:42 AM, Michael Davidsaver wrote:
>> On 3/22/20 8:37 AM, Mark Rivers via Core-talk wrote:
>>> Error (511,511) PV: 13BMDPG1:cam1:TriggerOverlap ReadOut
>> Looks like recGblDbaddrError() in Base 7.0. Maybe called with status==-1 ?
> Make that recGblRecordError(), I copied the wrong name...
- Error (511,511) Mark Rivers via Core-talk
- Re: Error (511,511) Michael Davidsaver via Core-talk
[Bug 1868486] [NEW] epicsMessageQueue lost messages mdavidsaver via Core-talk
<2020>
2025
2026
RE: Error (511,511) Mark Rivers via Core-talk
<2020>
2025
2026
