2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1868680] Re: Access Security file reload (asInit) fails
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 24 Mar 2020 15:25:54 -0000
It looks like I completely mis-read this code in asCa.c
and thought that asCaStop() was actually causing the worker to break.
It isn't.
I've reverted this change with bac8851132b28579dd9d85a3f0deed08f8d9a0b1
** Changed in: epics-base
     Assignee: (unassigned) => mdavidsaver (mdavidsaver)
    Milestone: None => 7.0.3.2
   Importance: Undecided => Medium
       Status: New => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1868680
Title:
Status in EPICS Base:
  Fix Committed
Bug description:
  Using EPICS Base 7.0.3.1, we observed that calling asInit() from IOC shell never returns and the shell hangs. The IOC continues to respond via CA and PVA but the new rules are not loaded and the shell remains blocked.
  The reload operation seems to hang in the asCaStop routine (asCa.c).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1868680/+subscriptions
Prev: Build failed: EPICS Base base-7.0-564 AppVeyor via Core-talk
Next: [Bug 1868486] Re: epicsMessageQueue lost messages mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Bug 1868680] Re: Access Security file reload (asInit) fails Andrew Johnson via Core-talk
ANJ, 28 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
