2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: add tech-talk and core-talk to gmane
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ben Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 6 Apr 2020 17:37:30 +0000
Hi Ben,
On Apr 5, 2020, at 2:10 AM, Ben Franksen via Core-talk <core-talk at aps.anl.gov> wrote:
In case you don't know what gmane is: it is a service that converts a
public mailing list to a news portal, so that one can access the mailing
list via NNTP. For instance, git at vger.kernel.org is mirrored on
news.gmane.io as gmane.comp.version-control.git .
I was going to request tech-talk and core-talk be added there as
gmane.comp.epics.user and gmane.comp.epics.devel, respectively. But the
site warns me that I should first ask the list maintainers if they
agree, hence this email.
Are you aware that I publish a full-text RSS feed of the EPICS mailing lists as part of their archives? I’m not sure if that would be sufficient for your needs or not, but I find these feeds very useful. Links to them can be found on the main page for the list, see here for the core-talk URLs.
I don’t particularly object to your signing up the lists to gmane, but I suspect the demand would be rather low, and gmane appears to be a 1-man shop. See these two lwn.net items for some news about it. I haven’t used NNTP myself for a very long time; does gmane offer a bidirectional gateway or is it just a read-only feed?
I can also point you to the raw list-archive mbox files if gmane has a way to import them.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: add tech-talk and core-talk to gmane Ben Franksen via Core-talk
Prev: Jenkins build is still unstable: epics-base-3.15-win32-test #285 APS Jenkins via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: add tech-talk and core-talk to gmane Ben Franksen via Core-talk
Next: Re: add tech-talk and core-talk to gmane Ben Franksen via Core-talk
ANJ, 07 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
