2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: AppVeyor issue
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Konrad, Martin" <konrad at frib.msu.edu>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 13 Apr 2020 11:04:48 -0700
What does the Export YAML give you?
I see:
> version: 1.0.{build}
> build:
>   verbosity: minimal
I don't think .appveyor.yml vs appveyor.yml makes a difference so long as
there is only one of the two.
Other than this, the only config I have changed is under General to enable
"Rolling Builds" and "Skip branches without appveyor.yml".
On 4/13/20 10:40 AM, Konrad, Martin via Core-talk wrote:
> Hi Michael,
> On 4/13/20 1:04 PM, mdavidsaver via Core-talk wrote:
>> Have you somehow changed the default image?  It seems to be 2019,
>> however the assumed default is 2015 (the default default).
> I checked my configuration. You're right: The build worker image was set
> to "Visual Studio 2019". I changed it to "Visual Studio 2015" but it
> seems like AppVeyor is not picking up this change (I hit the "new build"
> button to test the updated configuration):
> https://ci.appveyor.com/project/MartinKonrad/epics-base-github/build/job/xek709hm1j39ocas
> Am I missing something? Or could this be an issue with the appveyor.yml
> that comes with EPICS 3.15? BTW: The file name is "appveyor.yml" on the
> 3.15 branch and ".appveyor.yml" on the EPICS 7.0 branch - is that how it
> should be?
> -Martin
AppVeyor issue Konrad, Martin via Core-talk
Prev: AppVeyor issue Konrad, Martin via Core-talk
Next: Re: AppVeyor issue Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 13 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
