2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: AppVeyor issue
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 14 Apr 2020 18:15:46 +0200
On Mon, 13 Apr 2020 at 22:49, Konrad, Martin via Core-talk <core-talk at aps.anl.gov> wrote:
Hi Freddie,
> you could specify this image explicitly for the 10.0 11.0 12.0 and
> 14.0 toolchains (as is done for mingw in the file)
Thanks, that works :-) After deleting the project and starting from
scratch I believe that's actually the only thing that fixes my problem
(setting the default in the settings did NOT work for me - AppVeyor is
ignoring that the same way it is ignoring what should be their own
default...).
The image variable is definitely treated different from other environment variables.
What I found:
Once you set it in the common environment settings in your .appveyor.yml (matrix/environment) configuration, any per-job setting will *not* overwrite. (Different from other environment variables.)
BTW. I would prefer time being invested in checking/fixing the PullRequest for ci-scripts that adds AppVeyor support. I don't have any feedback yet, and this is the main issue keeping me from replacing the existing AppVeyor integration in base (that you are trying to fix).
Thanks a lot!
~Ralph
Re: AppVeyor issue Johnson, Andrew N. via Core-talk
AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Michael Davidsaver via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks Ben Franksen via Core-talk
Next: AppVeyor native Windows build support for ci-scripts (Beta) Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: AppVeyor issue Konrad, Martin via Core-talk
Next: Re: AppVeyor issue Johnson, Andrew N. via Core-talk
ANJ, 14 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
