2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: Marty Kraimer via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 16 Apr 2020 07:17:24 -0400
In Dirk's message the following appears:
    if (i<10)
        doThis(i);
    else
I have seen this cause problems when
doThis(i);
is changed from a single statement to multiple statements.
Better is
 if (i<10) {
    doThis(i);
 } else {
Marty
On 4/16/20 3:42 AM, Dirk Zimoch via Core-talk wrote:
What is your favorite coding style, mine looks like this:
int function(int a, int b)
     int i;
     for (i=a; i<b; i++)
         if (i<10)
             doThis(i);
         else
             switch (i)
                 case 42:
                     doSomethingSpecial();
                     break;
                 default:
                     doTheNormalThing(i, a, b);
                     break;
     return 0;
AW: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Zimoch Dirk (PSI) via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Jenkins build is still unstable: epics-base-3.15-win32-test #290 APS Jenkins via Core-talk
Next: Build failed: epics-base base-fix-epicsFindSymbol-463 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Next: AW: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Zimoch Dirk (PSI) via Core-talk
ANJ, 17 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
