2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: AW: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: Marty Kraimer <mrkraimer at comcast.net>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 17 Apr 2020 09:31:33 +0000
Hi Marty,
I agree that un-braced one-line if or else blocks may be a problem when changing them to more than one line. Even more when this happens invivibly when doThis() is a macro that expands to multiple statements ( and is not wrapped with  do { ... } while(0)  ).
I only wanted to express that I am a bit agnostic about these one liners.
However, I prefer them without braces when they are a single return, break, continue, or goto statement.
Anyway, I will not touch braces for now because of the git blame thing. But it would be nice to have an agreement on a  preference for future code.
Dirk
-----Ursprüngliche Nachricht-----
Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Marty Kraimer via Core-talk
Gesendet: Donnerstag, 16. April 2020 13:17
An: core-talk at aps.anl.gov
Betreff: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
In Dirk's message the following appears:
>     if (i<10)
>         doThis(i);
>     else
I have seen this cause problems when
doThis(i);
is changed from a single statement to multiple statements.
Better is
  if (i<10) {
     doThis(i);
  } else {
Marty
On 4/16/20 3:42 AM, Dirk Zimoch via Core-talk wrote:
> What is your favorite coding style, mine looks like this:
> int function(int a, int b)
>      int i;
>      for (i=a; i<b; i++)
>          if (i<10)
>              doThis(i);
>          else
>              switch (i)
>                  case 42:
>                      doSomethingSpecial();
>                      break;
>                  default:
>                      doTheNormalThing(i, a, b);
>                      break;
>      return 0;
Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Marty Kraimer via Core-talk
Prev: Build failed: EPICS Base base-7.0-586 AppVeyor via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Marty Kraimer via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Ralph Lange via Core-talk
ANJ, 17 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
