2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: tapfiles double-colon rule
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 21 Apr 2020 12:23:53 +0200
On Tue, 21 Apr 2020 at 08:25, Ben Franksen via Core-talk <core-talk at aps.anl.gov> wrote:
I am sure you two are aware of the difference, but people not so
familiar with GNU make intricacies may be confused.
Absolutely right. No reason to talk gibberish.
Have a look at Base's PR#70 - Andrew separated out things very nicely. I am getting some progress on a Google Test for EPICS integration which now easily fits itself into the testing targets of the EPICS build system.
My original double-colon approach was minimally invasive but clearly not the best way to handle this.
NB. Ran into a minor bug in make (4.2.1): if you're defining multiple grouped target rules (that use the '&:' separator), make creates bogus warnings about "overriding recipe for target '&'" - the rules work fine, though.
Cheers,
~Ralph
Re: tapfiles double-colon rule Johnson, Andrew N. via Core-talk
Re: tapfiles double-colon rule Ralph Lange via Core-talk
Re: tapfiles double-colon rule Ben Franksen via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build failed: epics-base base-appveyor-17 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: tapfiles double-colon rule Ben Franksen via Core-talk
Next: Re: tapfiles double-colon rule Johnson, Andrew N. via Core-talk
ANJ, 21 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
