But these are *not* cross-builds.
With the mingw32 tool chain, you are using a 32bit compiler executable to build 32bit artifacts.
It's the same as on Intel based Linux or Windows, where you can run the 32bit native compilers on a 64bit system.
Also, this is not a particular configuration, but the out-of-the-box
standard on MSYS2/MinGW systems. The installer creates two icons
"MinGW32 shell" and "MinGW64 shell" that start MSYS2 with the
appropriate toolchain setting.
I was assuming the EpicsHostArch script to be a user convenience
service, trying to determine the correct EPICS host architecture for the
context it is run in. The environment settings in a "MinGW32 shell" or
"MinGW64 shell" clearly indicate which toolchain is to be used. IMHO,
the EpicsHostArch script should output the setting for the intended
toolchain.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1873406
Title:
EpicsHostArch script does not detect recent MSYS2/MinGW setups on
Windows
Status in EPICS Base:
New
Status in EPICS Base 3.15 series:
New
Status in EPICS Base 7.0 series:
New
Bug description:
On MSYS2/MinGW installations, the EpicsHostArch script does not
recognize the host platform correctly.
64bit:
$ ./startup/EpicsHostArch
lib/perl/EpicsHostArch.pl: Architecture 'x86_64-msys-thread-multi' not recognized
32bit:
Which is not surprising, as the underlying MSYS2 subsystem is the
same, and the difference is in the environment settings that point to
the appropriate toolchain.
64bit:
$ echo $PATH
/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
$ printenv | grep MSYSTEM
MSYSTEM_CARCH=x86_64
MSYSTEM_CHOST=x86_64-w64-mingw32
MSYSTEM_PREFIX=/mingw64
MSYSTEM=MINGW64
32bit:
$ echo $PATH
/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
MSYSTEM_CARCH=i686
MSYSTEM_CHOST=i686-w64-mingw32
MSYSTEM_PREFIX=/mingw32
MSYSTEM=MINGW32
NB: I am impressed by the clarity and simplicity of MSYS2 / MinGW
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1873406/+subscriptions
- [Bug 1873406] [NEW] EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
[Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
<2020>
2025
2026
<2020>
2025
2026
