I would say, in cases where the user runs the compiler setup (vsvarsall or equivalent script) first, EpicsHostArch could look at a few environment variables and figure out the intended setting in most cases.
It would not detect all possible cases on all possible platforms, certainly, but should the inability to reach perfection keep us from improving it?
Since you do run your compiler setup batch beforehand, I am sure
EpicsHostArch could perfectly tell which of those targets you want to
build in your Strawberry field.
Older free VisualStudio versions (2008, 2010, 2012) that don't offer the
64bit compiler are the main 32bit reasons I can think of. Not sure about
legacy/embedded systems - are those running Windows?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1873406
Title:
EpicsHostArch script does not detect recent MSYS2/MinGW setups on
Windows
Status in EPICS Base:
New
Status in EPICS Base 3.15 series:
New
Status in EPICS Base 7.0 series:
New
Bug description:
On MSYS2/MinGW installations, the EpicsHostArch script does not
recognize the host platform correctly.
64bit:
$ ./startup/EpicsHostArch
lib/perl/EpicsHostArch.pl: Architecture 'x86_64-msys-thread-multi' not recognized
32bit:
Which is not surprising, as the underlying MSYS2 subsystem is the
same, and the difference is in the environment settings that point to
the appropriate toolchain.
64bit:
$ echo $PATH
/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
$ printenv | grep MSYSTEM
MSYSTEM_CARCH=x86_64
MSYSTEM_CHOST=x86_64-w64-mingw32
MSYSTEM_PREFIX=/mingw64
MSYSTEM=MINGW64
32bit:
$ echo $PATH
/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
MSYSTEM_CARCH=i686
MSYSTEM_CHOST=i686-w64-mingw32
MSYSTEM_PREFIX=/mingw32
MSYSTEM=MINGW32
NB: I am impressed by the clarity and simplicity of MSYS2 / MinGW
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1873406/+subscriptions
- [Bug 1873406] [NEW] EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Build failed: epics-base base-alarm-msg-472 AppVeyor via Core-talk
Build failed: epics-base base-use-ci-scripts-3.15-316 AppVeyor via Core-talk
<2020>
2025
2026
Re: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ben Franksen via Core-talk
[Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Greg Huff via Core-talk
<2020>
2025
2026
