2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: c++ thread_local and atexit()
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 24 Apr 2020 14:36:55 -0700
FYI. glibc at least seems not to follow the required ordering when destructing
thread_local objects on the main thread.
I read the language at
https://en.cppreference.com/w/cpp/utility/program/exit
as saying that thread_local destruction and atexit callbacks should be mixed
based on the reverse order in of constructors and atexit() calls.
However, glibc strictly destroys all thread_local before running
any atexit callbacks.
https://github.com/bminor/glibc/blob/5f72f9800b250410cad3abfeeb09469ef12b2438/stdlib/exit.c#L38
Prev: Re: [Merge] ~johill-lanl/epics-base/+git/epics-base:timer-queue-fix into epics-base:7.0 Martin Konrad via Core-talk
Next: Build failed: epics-base base-fix-epicsFindSymbol-473 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 27 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
