2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Base CI tests on MacOS failing
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 27 Apr 2020 18:04:15 +0200
On Mon, 27 Apr 2020 at 16:53, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
Back in Feb. I added testImpreciseTiming() to epicsUnitTest.h, and used it
in some of the common (apparently) false positives failures.  Starting with
epicsEventTest (on 7.0) to mark these tests specific TODO on CI runs.
https://github.com/epics-base/epics-base/commit/819b0de65b92d29d2ab26b0a2e36390ba0e17f71
Sounds good, I will have a look.
So having the appveyor tests run with EPICS_TEST_IMPRECISE_TIMING=YES is a
first step.
All tests on all platforms? Just the critical tests, on all platforms? All test on the critical platform? Or just the failing one, just on the critical platform?
Platform being MacOS on Travis-CI, btw.
Cheers,
~Ralph
Re: Base CI tests on MacOS failing Michael Davidsaver via Core-talk
Base CI tests on MacOS failing Ralph Lange via Core-talk
Prev: Re: Base CI tests on MacOS failing Michael Davidsaver via Core-talk
Next: Build completed: epics-base base-use-ci-scripts-3.15-328 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: Base CI tests on MacOS failing Michael Davidsaver via Core-talk
ANJ, 27 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
