Dear all,
The 3.15 and 7.0 branches are now switched over to use the shared ci-scripts module for their Travis-CI and AppVeyor builds. On Travis, the MacOS builds fail their tests. The epicsTimerTest fails the 5% error threshold in some of its cases. Typically like this:
This seems to have gotten worse as the shared ci-scripts now run the tests on Travis-CI using parallel make (as on AppVeyor/Windows) - the former scripts were running the tests serially. How should we proceed? Timing is notoriously weird on CI builder machines - should this test be run with higher thresholds on CI? Or be moved to the performance tests (not run as part of the build at all)? Cheers, ~Ralph
| ANJ, 27 Apr 2020 |
Home
News
About
Talk
Base
Modules
Extensions
