2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Base CI tests on MacOS failing
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 27 Apr 2020 16:45:03 +0200
On 4/27/20 3:01 PM, Ralph Lange via Core-talk wrote:
Dear all,
The 3.15 and 7.0 branches are now switched over to use the shared ci-scripts module for their Travis-CI and AppVeyor builds.
On Travis, the MacOS builds fail their tests. The epicsTimerTest fails the 5% error threshold in some of its cases. Typically like this:
    epicsTimerTest.tap ........... 1/41
    not ok  4 - 5.604376 < 5.000000, delay = 1.100000 s, error =
    0.061648 s (5.6 %)
    not ok  5 - 12.089890 < 5.000000, delay = 1.200000 s, error =
    0.145079 s (12.1 %)
    not ok  7 - 9.455878 < 5.000000, delay = 1.400000 s, error =
    0.132382 s (9.5 %)
    not ok 16 - 5.582973 < 5.000000, delay = 2.300000 s, error =
    0.128408 s (5.6 %)
    not ok 20 - 5.313693 < 5.000000, delay = 2.700000 s, error =
    0.143470 s (5.3 %)
    epicsTimerTest.tap ........... Failed 5/41 subtests
This seems to have gotten worse as the shared ci-scripts now run the tests on Travis-CI using parallel make (as on AppVeyor/Windows) - the former scripts were running the tests serially.
How should we proceed? Timing is notoriously weird on CI builder machines - should this test be run with higher thresholds on CI? Or be moved to the performance tests (not run as part of the build at all)?
Salut Ralph,
My spontaneous feeling, with the risk of being wrong: Try to run them.
What is the difference between a highly-loaded (soft) IOC and a machine
running ci scripts, probably highly loaded as well ?
May be not so much.
As we have 25% VAT here, taking half of it as the threshold could work ?
12.5 % ?
/Torsten
Cheers,
~Ralph
Base CI tests on MacOS failing Ralph Lange via Core-talk
Prev: Base CI tests on MacOS failing Ralph Lange via Core-talk
Next: Re: Base CI tests on MacOS failing Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 27 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
