That might not be true for 3.15 which is where Heinz is working; I only
build the RTEMS qemu target on my 7.0 branch, so I'm not sure.
I applied his latest patch to my 3.15 branch and my uC5282 target built
successfully. I then manually applied it to the 7.0 branch and it builds
successfully there too. Of course the change itself is in a routine that
is called from epicsThreadShow() so we don't have a test for it. I added
a call to the end of MAIN() in epicsThreadTest.cpp and it seemed to work
on the qemu target:
0a010001 52 147/108 RUN _main_
I'm happy to apply a version of this patch to 3.15, any objections?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1812084
Title:
Build failure on RTEMS 4.10.2
Status in EPICS Base:
Confirmed
Status in EPICS Base 3.15 series:
Confirmed
Status in EPICS Base 7.0 series:
Confirmed
Bug description:
Michael Westfall reported:
When compiling base R3.14.12.7 for RTEMS 4.10.2, I get the following
error:
/gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS -I/gem_swdev1/epics/R3.14.12.7/base/include ../../../src/libCom/osi/os/RTEMS/osdThread.c
../../../src/libCom/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'current_priority'
make[3]: *** [osdThread.o] Error 1
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1812084/+subscriptions
[Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
Re: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 Heinz Junkes via Core-talk
<2020>
2025
2026
<2020>
2025
2026
