Thanks for all your information.
I did exactly the same thing this afternoon. It just kept getting stuck
somewhere. Now I've taken the commands
from the history and now it works (in Epics 7 ayt least)?
in epics 7 :
qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net
nic,model=ne2k_pci -net user,restrict=yes -kernel libComTestHarness
EPICS Test Harness Results
All tests successful.
Programs=37, Tests=3046, 234 wallclock secs
ok 2 - counter() called once
ok 3 - unregistered counter() not called
ok 4 - Registered mainExit()
# threadA starting
ok 5 - Registered atExit(0x34d780)
ok 6 - Registered atThreadExit(0x34d780)
# threadA waiting for atExit
# threadB starting
ok 7 - Registered atExit(0x34d7d0)
ok 8 - Registered atThreadExit(0x34d7d0)
# threadB waiting for atExit
# Calling epicsExit
ok 9 - threadB reached atExit
ok 10 - threadB terminating
ok 11 - threadB destroying pinfo
ok 12 - threadA reached atExit
ok 13 - threadA terminating
ok 14 - threadA destroying pinfo
ok 15 - Reached mainExit
Results
Tests: 15
Passed: 15 = 100.00%
Epics 3.15 there is no rtems-pc368-qemu, I made it with
make -j2 RTEMS_QEMU_FIXUPS=YES
calling
is stuck, now output, no progress,
without "-display none" see Screenshot.
Danke, Heinz
On 2020-05-13 19:27, mdavidsaver wrote:
>> Unfortunately I lost the thread how to use the qemu-system-i386
> emulator
> If you're building for the RTEMS-pc386-qemu target, it should be as
> simple as 'make runtests'.
> The specific incantation is found in makeTestfile.pl, and the
> individual
> .t files after a build.
> https://github.com/epics-base/epics-
> base/blob/7.0/src/tools/makeTestfile.pl#L41
> At the moment this is
> qemu-system-i386 -m 64 -no-reboot \
> -serial stdio -display none \
> -net nic,model=ne2k_pci -net user,restrict=yes \
> -kernel $exe
> You received this bug notification because you are a bug assignee.
> https://bugs.launchpad.net/bugs/1812084
> Title:
> Build failure on RTEMS 4.10.2
> Status in EPICS Base:
> Confirmed
> Status in EPICS Base 3.15 series:
> Confirmed
> Status in EPICS Base 7.0 series:
> Confirmed
> Bug description:
> Michael Westfall reported:
> When compiling base R3.14.12.7 for RTEMS 4.10.2, I get the following
> error:
> /gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc
> --pipe
> -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/
> -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic
> -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL
> -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048
> -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -MMD -I. -I../O.Common
> -I. -I../../../src/libCom/osi/os/RTEMS
> -I../../../src/libCom/osi/os/posix
> -I../../../src/libCom/osi/os/default -I..
> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
> -I../../../src/libCom/env -I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
> -I../../../src/libCom/logClient -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libCom/osi
> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
> -I../../../src/libCom/tsDefs
> -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS
> ../../../src/libCom/osi/os/RTEMS/osdThread.c
> ../../../src/libCom/osi/os/RTEMS/osdThread.c: In function
> 'showInternalTaskInfo':
> ../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error:
> 'Thread_Control' has no member named 'real_priority'
> ../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error:
> 'Thread_Control' has no member named 'current_priority'
> ../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error:
> ../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error:
> make[3]: *** [osdThread.o] Error 1
> To manage notifications about this bug go to:
> https://bugs.launchpad.net/epics-base/+bug/1812084/+subscriptions
** Attachment added: "Screenshot_20200513_203752.png"
https://bugs.launchpad.net/bugs/1812084/+attachment/5371038/+files/Screenshot_20200513_203752.png
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
Title:
Confirmed
Confirmed
Confirmed
Bug description:
error:
/gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS -I/gem_swdev1/epics/R3.14.12.7/base/include ../../../src/libCom/osi/os/RTEMS/osdThread.c
../../../src/libCom/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'current_priority'
- [Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
[Bug 1812084] Re: Build failure on RTEMS 4.10.2 Andrew Johnson via Core-talk
<2020>
2025
2026
<2020>
2025
2026
