> tests now depend on various other files
The RTEMS test harness executables remain self-contained, with necessary
test files baked into the executable.
Personally, I don't see skipping re-linking test executables as a major
slow down. At least when compared with compiling c++ code like
libpvAccess.
@Andrew, Have you committed any of these changes? If not, then I would
rather defer this issue again.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842086
Title:
TestHarness should be TESTPROD instead of PROD
Status in EPICS Base:
In Progress
Status in EPICS Base 7.0 series:
In Progress
Bug description:
Several "TestHarness" vxWorks and RTEMS products are built as
PROD_vxWorks and PROD_RTEMS instead of TESTPROD_vxWorks and
TESTPROD_RTEMS even though they depend on TESTLIB code. This seems a
bit inconsistent. Changing them to TESTPROD would allow to build EPICS
base without tests, which could speed up the development cycle in an
early phase when building the tests is not yet needed.
Attached is a patch for EPICS 7 base. The same could be done for the
submodules.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842086/+subscriptions
[Bug 1829919] Re: IOC segfaults when calling dbLoadRecords after iocInit mdavidsaver via Core-talk
[Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
<2020>
2025
2026
Build failed: epics-base base-7.0-509 AppVeyor via Core-talk
[Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD Andrew Johnson via Core-talk
<2020>
2025
2026
