2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1812084] Re: Build failure on RTEMS 4.10.2
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 24 May 2020 18:18:00 -0000
** Changed in: epics-base/7.0
       Status: In Progress => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1812084
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  Michael Westfall reported:
  When compiling base R3.14.12.7 for RTEMS 4.10.2, I get the following
  error:
  /gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=7400 -D__ppc_generic                   -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS -I/gem_swdev1/epics/R3.14.12.7/base/include         ../../../src/libCom/osi/os/RTEMS/osdThread.c
  ../../../src/libCom/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'current_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error: 'Thread_Control' has no member named 'current_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'current_priority'
  make[3]: *** [osdThread.o] Error 1
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1812084/+subscriptions
Prev: [Bug 1842086] Re: TestHarness should be TESTPROD instead of PROD mdavidsaver via Core-talk
Next: [Bug 1868486] Re: epicsMessageQueue lost messages mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
Next: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 Andrew Johnson via Core-talk
ANJ, 28 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
