2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 and VxWorks 6.9 for PPC604?
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "anj at anl.gov" <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>, "mdavidsaver at gmail.com" <mdavidsaver at gmail.com>
Date: Thu, 4 Jun 2020 08:55:09 +0000
I found that the option -fno-implicit-fp causes the problem. When adding it to the generic ppc32 configuration, I get
the same "unable to find a register to spill in class 'FLOAT_REGS'" error unless I add -fno-expensive-optimizations as
well.
I had originally added this option when I ran into strange run-time errors because an interrupt handler of some driver
had used floating point registers without being asked to do so for moving "long long" values. As the floating point
registers are not saved when entering interrupt mode, bad things happened to the interrupted thread.
On Wed, 2020-06-03 at 17:51 +0000, Johnson, Andrew N. wrote:
> I suspect that the CPU-specific code in gcc for the ppc604 target is older than for the ppc32 target and can’t cope with newer constructs, we’ve had similar issues before. That’s why I really want to encourage you try the ppc32 targets, I don’t think they will show these errors at all and switching will save you time investigating the problems.
> - Andrew
> On Jun 3, 2020, at 12:30 PM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
> > 3 files have problems implementing the pure virtual function epicsTimerNotify::expire(): fdmgr.cc line 152, epicsTime.cpp line 62 and epicsTimerTest.cpp line 319. What helps is -O1 or -no-expensive-optimizations.
> > As I expect problems with any code that implements expire() I have now added 'CXXFLAGS += -fno-expensive-optimizations' to the general options for that architecture, not only for the 3 failing files.
> > This does not yet solve the problem with typeCast.h.
> > More tests tomorrow.
> > > -----Ursprüngliche Nachricht-----
> > > Von: Michael Davidsaver <mdavidsaver at gmail.com>
> > > Gesendet: Mittwoch, 3. Juni 2020 18:48
> > > An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>; 'core-talk at aps.anl.gov' <core-
> > > Betreff: Re: AW: EPICS 7 and VxWorks 6.9 for PPC604?
> > > On 6/3/20 8:31 AM, Zimoch Dirk (PSI) wrote:
> > > > I will try the selective -fno-inline ...
> > > If vxworks 6.7 had gcc 4.1 then the threshold for using
> > > __attribute__((always_inline)) is now being crossed.
> > > https://github.com/epics-
> > > base/pvDataCPP/blob/0fa927afa7d92f490f92eb4906e27046080309e2/src/misc
> > > /pv/templateMeta.h#L15-L16
> > > > > Von: Zimoch Dirk (PSI)
> > > > > Gesendet: Mittwoch, 3. Juni 2020 17:30
> > > > > An: 'Michael Davidsaver' <mdavidsaver at gmail.com>; 'core-
> > > > > Betreff: AW: EPICS 7 and VxWorks 6.9 for PPC604?
> > > > > It's gcc 4.3.3.
> > > > > Using -O0 (as used to fix bug 1702298) in helps for fdmgr.cpp but not for
> > > > > typeCast.h.
> > > > > > Gesendet: Mittwoch, 3. Juni 2020 17:13
> > > > > > Betreff: Re: EPICS 7 and VxWorks 6.9 for PPC604?
> > > > > > For those of us who aren't so familiar with vxworks, which GCC version(s)
> > >  are
> > > > > > involved.
> > > > > > You may remember https://bugs.launchpad.net/epics-base/+bug/1702298
> > > > > > On 6/3/20 8:04 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > > > > > Has anyone already compiled EPICS 7 for VxWorks 6.9 for PPC604?
> > > > > > > I have problems:
> > > > > > > With -O2 it fails here:
> > > > > > > ../fdmgr/fdmgr.cpp: In member function 'virtual
> > > > > >  epicsTimerNotify::expireStatus timerForOldFdmgr::expire(const
> > >  epicsTime&)':
> > > > > > > ../fdmgr/fdmgr.cpp:152: error: unable to find a register to spill in class
> > > > > >  'FLOAT_REGS'
> > > > > > > ../fdmgr/fdmgr.cpp:152: error: this is the insn:
> > > > > > > (insn:HI 16 15 17 2 ../fdmgr/fdmgr.cpp:151 (set (reg:DF 126 [
> > >  D.11913.delay
> > > > > > >        (mem/s/j/c:DF (plus:SI (reg/f:SI 113 sfp)
> > > > > > >                (const_int 8 [0x8])) [0 D.11913.delay+0 S8 A64])) 336
> > > > > >  {*movdf_hardfloat32} (expr_list:REG_EQUIV (mem/s/j/c:DF (plus:SI (reg/f:SI
> > > > >  113
> > > > > > sfp)
> > > > > > >        (nil)))
> > > > > > > ../fdmgr/fdmgr.cpp:152: confused by earlier errors, bailing out
> > > > > > > With -O1 (or lower) it comliles the above but then fails here:
> > > > > > > ../../src/misc/pv/typeCast.h: In function
> > > > >  'void<unnamed>::castVTyped(size_t,
> > > > > > void*, const void*) [with TO = std::basic_string<char, std::char_traits<char>,
> > > > > > std::allocator<char> >, FROM = float]':
> > > > > > > ../../src/misc/pv/typeCast.h:195: sorry, unimplemented: inlining failed in
> > >  call
> > > > > > to 'TO epics::pvData::castUnsafe(const FROM&) [with TO =
> > > > > > std::basic_string<char, std::char_traits<char>, std::allocator<char> >, FROM
> > > > > > float]': recursive inlining
> > > > > > > ../../src/misc/typeCast.cpp:38: sorry, unimplemented: called from here
> > > > > > > At least the compiler is "sorry".  I feel much better.
> > > > > > > BTW: VxWorks 6.7 has no such problems.
> > > > > > > Dirk
> Complexity comes for free, simplicity you have to work for.
Re: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Re: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
AW: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Re: AW: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
AW: AW: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Re: EPICS 7 and VxWorks 6.9 for PPC604? Johnson, Andrew N. via Core-talk
Prev: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
Next: Re: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7 and VxWorks 6.9 for PPC604? Johnson, Andrew N. via Core-talk
ANJ, 04 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
