I just found that INP with arrays of 1 element seems buggy:
record(aai,"aai") {
field(NELM, 10)
field(FTVL, "DOUBLE")
field(INP, [42])
record(ai, "ai") {
field(INP, [42])
epics> dbgf src
epics> dbgf src.NORD
DBF_ULONG: 0 = 0x0
epics> dbgf ai
DBF_DOUBLE: 0
I'll have a look at this, too.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1881563
Title:
Empty arrays have undefined behavior
Status in EPICS Base:
In Progress
Status in EPICS Base 7.0 series:
In Progress
Bug description:
The behavior of arrays with 0 elements is inconsistent and seemingly
undefined. I made the fllowing observations:
1. Reading empty arrays with caget shows NELM values, all 0 except for
the first which sometimes contains strange not-quite-random numbers
(see bug report 1242919). I have observed values 0, 2.122e-314,
2.50321e-308, 22, 18, 2.02038e-39, 1441792, 1179648, 3.05948e-308,
also depending on the -d option (DBR type) of caget.
2. Reading empty arrays with camonitor shows no values.
3. A scalar input record reading INP or scalar output record reading
DOL (with OMSL closed_loop) from an empty array (aai, aao or waveform)
reliably reads the value 0 (tested with ai, bi, mbbi, mbbiDirect,
longin, stringin, ao, bo, mbbo, mboDirect, longout, stringout). This
is true for DB links as well as for CA, CP and CPP links.
4. An array record (aai, waveform) reading from an empty array does
not change its current value. It does not change NORD, it does not
clear the arrays elements, it does not show an alarm.
5. Writing 0 elements to an array with caput -a fails whith "Invalid
element count requested".
My opinion on this behavior is as follows:
1. Reading arrays with caget should return NORD elements, not NELM
elements. But if we put this side, the additional elements should all
be set to 0. For empty arrays, this includes the the first one (index
0).
2. This is correct behavior.
3. This is consistent but questionable. Converting an empy array to a
scalar should fail as there is no value to convert. But that might
break existing dbs. In that case this behavior should be documented.
(Or is it?)
4. This behavior is buggy. The receiving record should update its NORD
to 0.
5. It should be possible to write an empty array.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1881563/+subscriptions
- [Bug 1881563] [NEW] empty arrays have undefined bahavior Dirk Zimoch via Core-talk
Build failed: epics-base base-integration-529 AppVeyor via Core-talk
[Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
<2020>
2025
2026
[Bug 1881563] Re: Empty arrays have undefined behavior mdavidsaver via Core-talk
<2020>
2025
2026
