2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+385269 at code.launchpad.net
Date: Mon, 08 Jun 2020 13:21:42 -0000
The proposal to merge ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 has been updated.
Description changed to:
Links like
  field (INP, [42])
or
  field (INP, [])
did not work, while
  field (INP, [42,7])
or even
  field (INP, [42,])
were fine.
Instead, they were searching for records with the name "[42]" or "[]", respectively
Now they work as expected.
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/385269
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 noreply--- via Core-talk
ANJ, 22 Oct 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
