2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1882520] Re: Constant arrary input links of size 1 don't work
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 08 Jun 2020 21:11:50 -0000
tux% cat bad.db
record(ai, "") {
  field(DESC, "Test")
tux% softIoc -d bad.db                                                          dbLoadDatabase("/home/phoebus4/ANJ/epics/base/7.0/bin/linux-x86_64/../../dbd/softIoc.dbd")
softIoc_registerRecordDeviceDriver(pdbbase)
Error: dbRecordHead: Record name can't be empty
 at or before ")" in path "."  file "bad.db" line 1
Error: syntax error
dbLoadRecords: failed to load 'bad.db'
Error: Failed to load: bad.db
tux% cat bad.db
record(ai, "a b") {
  field(DESC, "Test")
record(ai, "a.b") {
  field(DESC, "Test")
record(ai, "a$b") {
  field(DESC, "Test")
record(ai, "a\"b") {
  field(DESC, "Test")
Bad character ' ' in record name "a b"
Bad character '.' in record name "a.b"
Bad character '$' in record name "a$b"
Bad character '"' in record name "a\"b"
dbLoadRecords("bad.db")
iocInit()
Starting iocInit
## EPICS R7.0.3.2-DEV
## Rev. R7.0.3.1-294-g75a3442669af831d8a6b
epics> dbl
a b
a.b
a$b
a\"b
The fact that the messages are printed before the command that caused
them is a feature of the new version of softIoc, but all those record
names do actually generate an error message when you load them. I did
that instead of erroring out because we didn't used to reject such
names, and as you have noticed some of those characters do work in some
situations.
Note that if I had been strict about checking names the BNL naming
convention that includes {} characters inside record names would have
been prohibited. As it is since we added JSON link types records cannot
be named "{something}", and the brace characters have not been added to
the documented list of legal record name characters.
I'm not in favor of our getting too strict about record names too
quickly.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Constant input links in array form with 1 element don't work and
  return an empty array.
  Example:
  field (INP, [42])
  As soon as a comma is present, it works:
  field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
[Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work mdavidsaver via Core-talk
Next: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 08 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
