I'd like to ask for some review of an idea I've been trying out
(funding courtesy of ESS) to be able to usefully represent
complex types as database fields. My immediate application is
to the PVA data containers shared_vector and PVStructure,
although there are others.
The way I've done this works, but wasn't my first idea. I won't
call it a hack, but it's not far removed. So I'm open to alternate
ways to accomplish this. (though I do think a solution is needed)
In short, I add a new DBR_VFIELD to the database module without
adding any DBF_* code. A short (and ugly) usage example is:
> DBADDR *paddress = ...;
> shared_vector<const void> aval;
> struct VField {
> const VFieldType *vtype;
> shared_vector<const void> *aval;
> } varg = {&vfSharedVector, &aval};
> dbGet(paddress, DBR_VFIELD, NULL, &varg, NULL);
This project involved changes to multiple modules in order to make
something testable. Even the changes to Base come in two parts.
Each has accompanying discussion.
1. Add alarm message and time tag to dbCommon in Base
Not directly related to DBR_VFIELD, but adds an alarm
message string, and time tag a la. PVA. Also, adds
a 'utag' server side filter which can apply a bitmask
to the time tag.
https://github.com/epics-base/epics-base/pull/71
2. Add DBR_VFIELD in Base
Also adds a new stdstringinRecord type as an example.
https://github.com/mdavidsaver/epics-base/pull/1
3. Apply DBR_VFIELD to QSRV
Adds svectorinRecord where VAL is shared_vector<const void>
aka reference counted pointer to an immutable array.
https://github.com/mdavidsaver/pva2pva/pull/3
4. Add device support for svectorinRecord to a driver
I picked this TCP socket based driver mainly because
I created a easy simulator. The driver is changed to
use shared_vector internally instead of copying arrays.
https://github.com/mdavidsaver/pscdrv/pull/1
The end result is driver which handles waveform data more
efficiently, and can also pass a time tag from the (simulated)
device, which can then be used to filter out some monitor updates
(eg. beam vs. no beam).
- Re: DBR_VFIELD and complex field types Ralph Lange via Core-talk
- Alarm messages (Re: DBR_VFIELD and complex field types) Michael Davidsaver via Core-talk
[Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
<2020>
2025
2026
[Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 noreply--- via Core-talk
<2020>
2025
2026
