2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Alarm messages (Re: DBR_VFIELD and complex field types)
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 26 Jun 2020 16:12:50 -0700
On 6/8/20 4:18 PM, Michael Davidsaver wrote:
> 1. Add alarm message and time tag to dbCommon in Base
> Not directly related to DBR_VFIELD, but adds an alarm
> message string, and time tag a la. PVA.  Also, adds
> a 'utag' server side filter which can apply a bitmask
> to the time tag.
> https://github.com/epics-base/epics-base/pull/71
Continuing the discussion/review of this multi-part series,
I'd like to go into detail about the first part or the first PR.
The added ability to provide a string describing alarms.
From the prospective of a device support author,
this interface can be summarized as:
> int recGblSetSevrMsg(void *precord, epicsEnum16 new_stat,
>                      epicsEnum16 new_sevr,
>                      const char *msg)
Were currently a device support might have:
> if(!connected)
>   recGblSetSevr(prec, READ_ALARM, INVALID_ALARM);
More information could be provided with:
> if(!connected)
>   recGblSetSevrMsg(prec, READ_ALARM, INVALID_ALARM, "No Conn");
Practically, this is a way to disambiguate status codes like READ_ALARM
or COMM_ALARM which tend to have multiple meanings.
From the prospective of a user, this message will appear in
a new AMSG field.  It can be accessed like any other record string field.
An additional benefit is that with QSRV it will appear as part of
the PVA alarm meta-data.  aka. the 'alarm.message' structure field.
The PR adds a couple of internal usages of recGblSetSevrMsg().
Probably the most interesting is to the link code so that
when a link operation signals an alarm, the link field name
is given as the alarm message.
So eg. it can be seen at a glance that INPE of a calcRecord
has set a LINK_ALARM.
Open questions:
* Is a printf()-like form of recGblSetSevrMsg() needed?
  (currently message length is limited to 40 characters)
* Does struct lset need changing?  (and how?)
  Needed for eg. MSS to copy message string
DBR_VFIELD and complex field types Michael Davidsaver via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-40 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: DBR_VFIELD and complex field types Johnson, Andrew N. via Core-talk
Next: Build failed: epics-base base-vfield-530 AppVeyor via Core-talk
ANJ, 27 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
