2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with ci-scripts v3.0.0?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 15 Jun 2020 14:18:02 +0200
Please use v3.0.1
Sorry for the inconvenience caused,
~Ralph
On Mon, 15 Jun 2020 at 14:12, Ralph Lange <ralph.lange at gmx.de> wrote:
Bug on my end when "improving" the error message for setup files not being found.
Just a moment, please...
Cheers,
~Ralph
On Mon, 15 Jun 2020 at 14:04, Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Ralph,
I just updated asyn to use the v.3.0.0 version of ci-scripts from epics-base on Github.  All of the asyn travis jobs are failing.
The jobs appear to be using the correct commit of ci-scripts.  This is from the log:
$ git submodule update --init --recursive
Submodule '.ci' (https://github.com/epics-base/ci-scripts) registered for path '.ci'
Cloning into '/home/travis/build/epics-modules/asyn/.ci'...
Submodule path '.ci': checked out '4690a977df3d8936a0aa6ae004ac80015c20caba'
However, all of the jobs fail with this error:
Loading setup files
Opening setup file .ci-local/base7.set
Traceback (most recent call last):
  File ".ci/cue.py", line 1010, in <module>
    main(sys.argv[1:])
  File ".ci/cue.py", line 1006, in main
    args.func(args)
  File ".ci/cue.py", line 644, in prepare
    source_set('defaults')
  File ".ci/cue.py", line 276, in source_set
    .format(ANSI_RED, name, setup_dirs, ANSI_RESET))
NameError: Setup file defaults.set does not exist in SETUP_PATH search path (['.ci-local', '.ci'])
The command "python .ci/cue.py prepare" failed and exited with 1 during .
Your build has been stopped.
I've probably done something wrong, but I don't understand why it is saying that defaults.set does not exist in .ci, because it should.  It is there on my local system with v3.0.0.
The same asyn/.travis-yml was working on the devel/cue-3.0 branch in the ralphlange/ci-scripts repository.
Re: Problem with ci-scripts v3.0.0? Mark Rivers via Core-talk
Re: Problem with ci-scripts v3.0.0? Ralph Lange via Core-talk
Prev: Re: Problem with ci-scripts v3.0.0? Ralph Lange via Core-talk
Next: Re: Problem with ci-scripts v3.0.0? Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 15 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
