2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvData-mac #186
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 22 Jun 2020 11:18:12 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-pvData-mac/186/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-pvData-mac
No credentials specified
 > git rev-parse --is-inside-work-tree # timeout=10
ERROR: Timeout after 10 minutes
FATAL: java.io.IOException: Unexpected termination of the channel
java.io.EOFException
	at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2735)
	at java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:3210)
	at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:895)
	at java.io.ObjectInputStream.<init>(ObjectInputStream.java:357)
	at hudson.remoting.ObjectInputStreamEx.<init>(ObjectInputStreamEx.java:49)
	at hudson.remoting.Command.readFrom(Command.java:142)
	at hudson.remoting.Command.readFrom(Command.java:128)
	at hudson.remoting.AbstractSynchronousByteArrayCommandTransport.read(AbstractSynchronousByteArrayCommandTransport.java:35)
	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:63)
Caused: java.io.IOException: Unexpected termination of the channel
	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:77)
Also:   hudson.remoting.Channel$CallSiteStackTrace: Remote call to mac-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1788)
		at hudson.remoting.Request.call(Request.java:202)
		at hudson.remoting.Channel.call(Channel.java:997)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:285)
		at com.sun.proxy.$Proxy105.hasGitRepo(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.hasGitRepo(RemoteGitImpl.java:284)
		at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1107)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1167)
		at hudson.scm.SCM.checkout(SCM.java:505)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1206)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1856)
		at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:428)
Caused: hudson.remoting.RequestAbortedException
	at hudson.remoting.Request.abort(Request.java:340)
	at hudson.remoting.Channel.terminate(Channel.java:1081)
	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:94)
ERROR: Step ‘Publish TAP Results’ failed: no workspace for epics-pvData-mac #186
Jenkins build is back to normal : epics-pvData-mac #187 APS Jenkins via Core-talk
Prev: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Jenkins build is back to normal : epics-pvData-mac #187 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 noreply--- via Core-talk
ANJ, 18 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
