Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0.
diff --git a/documentation/RELEASE_NOTES.md b/documentation/RELEASE_NOTES.md
index 6fd8061..274d65f 100644
--- a/documentation/RELEASE_NOTES.md
+++ b/documentation/RELEASE_NOTES.md
@@ -17,6 +17,36 @@ should also be read to understand what has changed since earlier releases.
<!-- Insert new items immediately below here ... -->
+### Support for empty arrays
+Several problems with empty arrays have been fixed.
+#### Changed dbr_size_n(TYPE,COUNT) macro
+When called with COUNT=0 the macro no longer returns the number of bytes
+required for a scalar (1 element) but for an empty array (0 elements).
+Make sure you don't call it with COUNT=0 when you really mean COUNT=1.
+#### Array records
+The soft supports of array records aai, waveform, and subArray as well as
+the aSub record type have been fixed to correctly report 0 elements read
+when reading empty arrays from an input link.
+#### Array support for dbpf
+The dbpf function now accepts arrays, including empty arrays, as a quoted
+whitespace separated list of values.
+#### Scalar records reading from empty arrays
+Scalar records reading from empty arrays via database links are now set to
+INVALID/LINK alarm status.
+Links have to call dbGet with pnRequest=NULL to be recognised as requests
+for scalars.
+This changes the semantics of pnRequest=NULL. It is now different from
+requesting 1 element, which is counted as an array request and may return
+a valid empty array.
## EPICS Release 7.0.4
diff --git a/modules/ca/src/client/db_access.h b/modules/ca/src/client/db_access.h
index 810f82f..ad10a88 100644
--- a/modules/ca/src/client/db_access.h
+++ b/modules/ca/src/client/db_access.h
@@ -516,7 +516,7 @@ struct dbr_ctrl_double{
#define dbr_size_n(TYPE,COUNT)\
-((unsigned)((COUNT)<=0?dbr_size[TYPE]:dbr_size[TYPE]+((COUNT)-1)*dbr_value_size[TYPE]))
+((unsigned)((COUNT)<0?dbr_size[TYPE]:dbr_size[TYPE]+((COUNT)-1)*dbr_value_size[TYPE]))
/* size for each type - array indexed by the DBR_ type code */
LIBCA_API extern const unsigned short dbr_size[];
diff --git a/modules/ca/src/client/nciu.cpp b/modules/ca/src/client/nciu.cpp
index 0a7e708..ebf30fe 100644
--- a/modules/ca/src/client/nciu.cpp
+++ b/modules/ca/src/client/nciu.cpp
@@ -328,7 +328,7 @@ void nciu::write (
if ( ! this->accessRightState.writePermit() ) {
throw cacChannel::noWriteAccess();
- if ( countIn > this->count || countIn == 0 ) {
+ if ( countIn > this->count) {
throw cacChannel::outOfBounds();
if ( type == DBR_STRING ) {
@@ -349,7 +349,7 @@ cacChannel::ioStatus nciu::write (
diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
index 9cda401..112b615 100644
--- a/modules/database/src/ioc/db/dbAccess.c
+++ b/modules/database/src/ioc/db/dbAccess.c
@@ -945,6 +945,11 @@ long dbGet(DBADDR *paddr, short dbrType,
if (offset == 0 && (!nRequest || no_elements == 1)) {
if (nRequest)
*nRequest = 1;
+ else if (no_elements < 1) {
+ status = S_db_onlyOne;
+ goto done;
if (!pfl || pfl->type == dbfl_type_rec) {
status = dbFastGetConvertRoutine[field_type][dbrType]
(paddr->pfield, pbuf, paddr);
diff --git a/modules/database/src/ioc/db/dbTest.c b/modules/database/src/ioc/db/dbTest.c
index 1193954..7000c46 100644
--- a/modules/database/src/ioc/db/dbTest.c
+++ b/modules/database/src/ioc/db/dbTest.c
@@ -363,8 +363,9 @@ long dbpf(const char *pname,const char *pvalue)
DBADDR addr;
long status;
- short dbrType;
- size_t n = 1;
+ short dbrType = DBR_STRING;
+ long n = 1;
+ epicsOldString *array = NULL;
if (!pname || !*pname || !pvalue) {
printf("Usage: dbpf \"pv name\", \"value\"\n");
@@ -379,16 +380,35 @@ long dbpf(const char *pname,const char *pvalue)
return -1;
- if (addr.no_elements > 1 &&
- (addr.dbr_field_type == DBR_CHAR || addr.dbr_field_type == DBR_UCHAR)) {
- dbrType = addr.dbr_field_type;
- n = strlen(pvalue) + 1;
- else {
- dbrType = DBR_STRING;
+ if (addr.no_elements > 1) {
+ if (addr.dbr_field_type == DBR_CHAR || addr.dbr_field_type == DBR_UCHAR) {
+ dbrType = addr.dbr_field_type;
+ n = (long)strlen(pvalue) + 1;
+ } else {
+ const char *p = pvalue;
+ for (n = 0; *p && n < addr.no_elements; n++) {
+ while (isspace(*p)) p++;
+ while (*p && !isspace(*p)) {
+ if (p[0] == '\\' && p[1]) p++;
+ p++;
+ p = pvalue;
+ array = dbCalloc(n, sizeof(epicsOldString));
+ char* c = array[n];
+ *c++=*p++;
+ pvalue = (void*)array;
- status = dbPutField(&addr, dbrType, pvalue, (long) n);
+ status = dbPutField(&addr, dbrType, pvalue, n);
+ free(array);
dbgf(pname);
return status;
diff --git a/modules/database/src/std/dev/devAaiSoft.c b/modules/database/src/std/dev/devAaiSoft.c
index 1f57656..0fbb114 100644
--- a/modules/database/src/std/dev/devAaiSoft.c
+++ b/modules/database/src/std/dev/devAaiSoft.c
@@ -60,9 +60,10 @@ static long init_record(dbCommon *pcommon)
status = dbLoadLinkArray(plink, prec->ftvl, prec->bptr, &nRequest);
- if (!status && nRequest > 0) {
+ if (!status) {
prec->nord = nRequest;
prec->udf = FALSE;
+ return status;
return 0;
@@ -74,7 +75,7 @@ static long readLocked(struct link *pinp, void *dummy)
long nRequest = prec->nelm;
long status = dbGetLink(pinp, prec->ftvl, prec->bptr, 0, &nRequest);
+ if (!status) {
prec->udf = FALSE;
@@ -89,8 +90,12 @@ static long read_aai(aaiRecord *prec)
epicsUInt32 nord = prec->nord;
struct link *pinp = prec->simm == menuYesNoYES ? &prec->siol : &prec->inp;
- long status = dbLinkDoLocked(pinp, readLocked, NULL);
+ long status;
+ if (dbLinkIsConstant(pinp))
+ return 0;
+ status = dbLinkDoLocked(pinp, readLocked, NULL);
if (status == S_db_noLSET)
status = readLocked(pinp, NULL);
diff --git a/modules/database/src/std/dev/devSASoft.c b/modules/database/src/std/dev/devSASoft.c
index be32af4..8db192f 100644
--- a/modules/database/src/std/dev/devSASoft.c
+++ b/modules/database/src/std/dev/devSASoft.c
@@ -65,7 +65,7 @@ static long init_record(dbCommon *pcommon)
status = dbLoadLinkArray(&prec->inp, prec->ftvl, prec->bptr, &nRequest);
+ if (!status)
subset(prec, nRequest);
return status;
@@ -115,7 +115,7 @@ static long read_sa(subArrayRecord *prec)
status = readLocked(&prec->inp, &rt);
- if (!status && rt.nRequest > 0) {
+ if (!status) {
subset(prec, rt.nRequest);
if (nord != prec->nord)
diff --git a/modules/database/src/std/dev/devWfSoft.c b/modules/database/src/std/dev/devWfSoft.c
index 0a089b8..29a617b 100644
--- a/modules/database/src/std/dev/devWfSoft.c
+++ b/modules/database/src/std/dev/devWfSoft.c
@@ -41,7 +41,7 @@ static long init_record(dbCommon *pcommon)
long nelm = prec->nelm;
long status = dbLoadLinkArray(&prec->inp, prec->ftvl, prec->bptr, &nelm);
- if (!status && nelm > 0) {
+ if (!status) {
prec->nord = nelm;
prec->udf = FALSE;
@@ -77,11 +77,14 @@ static long read_wf(waveformRecord *prec)
rt.ptime = (dbLinkIsConstant(&prec->tsel) &&
prec->tse == epicsTimeEventDeviceTime) ? &prec->time : NULL;
+ if (dbLinkIsConstant(&prec->inp))
+ return 0;
status = dbLinkDoLocked(&prec->inp, readLocked, &rt);
+ if (!status) {
prec->nord = rt.nRequest;
prec->udf = FALSE;
diff --git a/modules/database/src/std/rec/aSubRecord.c b/modules/database/src/std/rec/aSubRecord.c
index 666558b..1bcbb63 100644
--- a/modules/database/src/std/rec/aSubRecord.c
+++ b/modules/database/src/std/rec/aSubRecord.c
@@ -277,10 +277,9 @@ static long fetch_values(aSubRecord *prec)
long nRequest = (&prec->noa)[i];
status = dbGetLink(&(&prec->inpa)[i], (&prec->fta)[i], (&prec->a)[i], 0,
&nRequest);
- if (nRequest > 0)
- (&prec->nea)[i] = nRequest;
if (status)
return status;
+ (&prec->nea)[i] = nRequest;
return 0;
- Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 mdavidsaver via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
- [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 noreply--- via Core-talk
[Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
Build failed in Jenkins: epics-pvData-mac #186 APS Jenkins via Core-talk
<2020>
2025
2026
Build failed: epics-base base-test-reuse-562 AppVeyor via Core-talk
<2020>
2025
2026
