2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+386175 at code.launchpad.net
Date: Thu, 16 Jul 2020 07:48:22 -0000
Diff comments:
> diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
> index 9cda401..4fbfa96 100644
> --- a/modules/database/src/ioc/db/dbAccess.c
> +++ b/modules/database/src/ioc/db/dbAccess.c
> @@ -1329,25 +1334,21 @@ long dbPut(DBADDR *paddr, short dbrType,
>          status = prset->get_array_info(paddr, &dummy, &offset);
>          /* paddr->pfield may be modified */
>          if (status) goto done;
> -    } else
> -        offset = 0;
> -    if (no_elements <= 1) {
> -        status = dbFastPutConvertRoutine[dbrType][field_type](pbuffer,
> -            paddr->pfield, paddr);
> -        nRequest = 1;
> -    } else {
>          if (no_elements < nRequest)
>              nRequest = no_elements;
>          status = dbPutConvertRoutine[dbrType][field_type](paddr, pbuffer,
>              nRequest, no_elements, offset);
> -    /* update array info */
> -    if (!status &&
> -        paddr->pfldDes->special == SPC_DBADDR &&
Doesn't this check for both? It is the same check that was in the code before.
if (paddr->pfldDes->special == SPC_DBADDR &&
        prset && prset->get_array_info)
> -        prset && prset->put_array_info) {
> -        status = prset->put_array_info(paddr, nRequest);
> +        /* update array info */
> +        if (!status)
> +            status = prset->put_array_info(paddr, nRequest);
> +    } else {
> +        if (nRequest < 1) {
> +            recGblSetSevr(precord, LINK_ALARM, INVALID_ALARM);
> +        } else {
> +            status = dbFastPutConvertRoutine[dbrType][field_type](pbuffer,
> +                paddr->pfield, paddr);
> +            nRequest = 1;
>      /* Always do special processing if needed */
> diff --git a/modules/database/src/ioc/db/dbTest.c b/modules/database/src/ioc/db/dbTest.c
> index 1193954..25782a2 100644
> --- a/modules/database/src/ioc/db/dbTest.c
> +++ b/modules/database/src/ioc/db/dbTest.c
> @@ -379,16 +380,41 @@ long dbpf(const char *pname,const char *pvalue)
>          return -1;
> -    if (addr.no_elements > 1 &&
> -        (addr.dbr_field_type == DBR_CHAR || addr.dbr_field_type == DBR_UCHAR)) {
> -        dbrType = addr.dbr_field_type;
> -        n = strlen(pvalue) + 1;
> -    else {
> -        dbrType = DBR_STRING;
> +    if (addr.no_elements > 1) {
> +        if (addr.dbr_field_type == DBR_CHAR || addr.dbr_field_type == DBR_UCHAR) {
> +            dbrType = addr.dbr_field_type;
> +            n = (long)strlen(pvalue) + 1;
> +        } else {
> +            const char *p = pvalue;
I will give dbPutConvertJSON a try...
> +            for (n = 0; *p && n < addr.no_elements; n++) {
> +                while (isspace(*p)) p++;
> +                while (*p && !isspace(*p)) {
> +                    if (p[0] == '\\' && p[1]) p++;
> +                    p++;
> +            p = pvalue;
> +            array = dbCalloc(n, MAX_STRING_SIZE);
> +                char* c = &array[n*MAX_STRING_SIZE];
> +                pvalue = p;
> +                    if (c >= &array[(n+1)*MAX_STRING_SIZE]-1) {
> +                        printf("Value [%ld] %.*s too long\n", n, (int)(p-pvalue), pvalue);
> +                        free(array);
> +                        return -1;
> +                    *c++=*p++;
> +            pvalue = array;
> -    status = dbPutField(&addr, dbrType, pvalue, (long) n);
> +    status = dbPutField(&addr, dbrType, pvalue, n);
> +    free(array);
>      dbgf(pname);
>      return status;
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-50 AppVeyor via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-50 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 17 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
