+The `ca_array_put()` and `ca_array_put_callback()` routines now accept an
+element count of zero, and will write a zero-length array to the PV if
+possible. No error will be raised if the target is a scalar field though,
+and the field's value will not be changed.
I thought I set the target scalar record to INVALID/LINK.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
<2020>
2025
2026
Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
[Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 noreply--- via Core-talk
<2020>
2025
2026
