2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+386175 at code.launchpad.net
Date: Mon, 06 Jul 2020 13:42:19 -0000
Finally put is fixed as well. I changed dbPut to set the target to INVALID/LINK if the target is a scalar and 0 elements are put. Only the target record goes to alarm state, not the sending record.
The target is then processed normally if the link is PP, as before only that before if was processed with no alarm and value 0.
If the target happens to be an array of max length 1, it is set to an empty array and not to alarm. For that I always use now the array implementation if the target is a SPC_DBADDR field with array_info(), even if the target has only 1 element. That allowed me to streamline the dbPut code a bit.
This change works for db links, CA links and as well for `caput -a 0` (empty array put) to a scalar field. Is it ok to call this case a "LINK_ALARM"? I cannot really distinguish between caput and any other put in dbPut. An alternative would be to check the target in the CA server and report an error to the caller when trying to put an empty array into a scalar. But that would probably affect CA links as well and generate an error in the sending record.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-7.0-578 AppVeyor via Core-talk
Next: [Bug 1884339] Re: Inaccessible CA servers on Windows Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 13 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
